Car dies after starting...once a day
Old August 12th, 2011, 01:43 PM   #1
jonrhy05 is on a distinguished road
the first time i start my car every day, itll fire up, then die seconds later, if you immediately start it back up, itll idle up and down for a couple seconds then idle "fine". and by fine i mean itll run. however...it idles a few hundred rpm's high, after it runs for a minute, itll idle around 8-900...also, when you drive the car, it will idle high when you come to a stop, then will settle down after 20 seconds or more and idle at 8-900 again
so...vacuum leak or what?
Old August 12th, 2011, 06:32 PM   #2
Isambard's Avatar
2001 V6 1990 5.0
Isambard is on a distinguished road
Could be a vac leak, faulty TPS, dirty MAF. Try cleaning your intake with some MAF cleaner then search for a vac leak. TPS sensors are a tad expensive so try the easy and cheap fixes first.
Threads Similar to: Car dies after starting...once a day
HELP! car dies when starting out in gear Planert_nci 5.0 Mustangs 1 April 14th, 2011 04:59 PM
Car dies Fast02Pony 99-04 19 April 6th, 2011 08:50 PM
HELP! Car dies WhiteVenom 99-04 31 October 24th, 2010 02:07 PM
Dies? Stang6er V6 Mustangs 1 January 30th, 2010 01:13 AM
dies at 3k superman5.0 5.0 Mustangs 7 July 18th, 2007 05:26 PM
