input shaft prob
Old May 18th, 2007, 08:37 PM   #1
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
input shaft prob
the shaft on my buddys t5 he just bought has a longer input shaft then the older one. Can he still use it in his 88 gt or does he need to do something?
Old May 19th, 2007, 12:33 AM   #2
neverfastenough1's Avatar
Ok, you either have a 4cylinder tranny which should not be used behind a v-8, a 3.8 tranny, or a 94-95 v8 tranny. The sn95 transmissions have a much longer shaft and bellhousing to position the stick further back in the cockpit. You would have to change the input shaft, or modify your your gearshift position in the tunnel. The sn95 has a electronic triggered speedo instead of a cable with a gear. That is the case for the 6 cyl, not sure about the v8.
Threads Similar to: input shaft prob
drive shaft shop one piece steel shaft ok for automatic tran mustang fanatic 2005 - 2010 8 September 24th, 2007 02:21 AM
94 Cobra prob. 94gt5.0 94-95 8 September 19th, 2007 11:55 PM
sniper prob!! WLJohnson05 V6 Mustangs 41 July 30th, 2007 01:16 AM
clutch prob? thatonekidw/theGT Modular Mustangs 12 July 18th, 2007 10:29 PM
tech prob robert178 5.0 Mustangs 1 August 18th, 2006 10:08 AM
