Only fun til 4k rpms?
LinkBack (1) Thread Tools
Old August 16th, 2011, 08:57 PM   1 links from elsewhere to this Post. Click to view. #1
1987 Mustang GT
Nope
Atomyk is on a distinguished road
So, I just picked up a 5 spd 87 GT. Its got BBK chrome shorties, an aftermarket cam that neither myself or the previous owner know the specs of, a chopped up h-pipe, and dumped factory mufflers. I just did a full tune up (dist. cap, rotor, plugs, wires, fuel filter, base idle reset, checked TPS voltage, cleaned MAF, TB, and IAC) to help the idle, but it falls flat on its ass at WOT above 4k rpms. It seems to stop revving as quickly and just kinda sits there... so... anybody know why? It has been converted to mass air by the way.
Old August 16th, 2011, 09:31 PM   #2
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Why? Maybe the cam he put in is a shitty one and makes low end grunt but no steam up top. Stock 5.0s only make power till about 4K, shift around 4,800-5,000 depending on the car.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old August 16th, 2011, 10:46 PM   #3
1987 Mustang GT
Nope
Oh... That makes sense. Well dern. I figured with the way it lopes it would have more top end. Figures... So far, this car has been one big let down after the other.thanks for the help!
Old August 16th, 2011, 11:10 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
put on a good set of cylinder heads and intake, that should help some, but ya, the cam may be the problem but if you dont know any thing about it then its just a guessing game
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old August 27th, 2011, 03:18 AM   #5
1SICK5.0VERT's Avatar
modded 95 gt vert
1SICK5.0VERT is on a distinguished road
Check your plug wires and boots. Make sure all the wires are plugged onto the plugs and cap properly. I had a similar issue and it ended up being an arcing problem. Let the car run in the dark and have someone give it gas while you watch for an arc. Hope this helps
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
Old August 28th, 2011, 07:13 AM   #6
91cobra5.0's Avatar
98 Cobra
could be a fuel pump issue
Old August 28th, 2011, 08:42 AM   #7
Stdyhand is on a distinguished road
My engine is mostly stock right now and it doesn't make much power over 4k so I don't rev it that high very often. A Ford Tech said the stock 5.0's made their most power at around 2500-3k rpm which feels about right in my car.
If you want top end, you'll have to build it that way. I prefer most of my power down low since most of my time is in the city.
Old August 28th, 2011, 04:20 PM   #8
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
check your ignition system and your coil. Might not be getting enough spark to make her go. Does it run rich or lean when you start dying out.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/230062-only-fun-til-4k-rpms.html
Thread Car is laggy 1-4k rpms, After seafoam? | Club RSX Message Board | BoardReader This thread Refback August 24th, 2011 04:42 AM
Threads Similar to: Only fun til 4k rpms?
RPMs? 92mustang04yfz 2.3 Mustangs 18 September 27th, 2010 09:20 PM
What 14,200 RPMs looks like 69fastback The Clubhouse 26 February 23rd, 2010 02:06 AM
RPMs? Codeman V6 Mustangs 6 November 22nd, 2009 07:40 PM
what rpms? 04Roush 99-04 9 February 5th, 2008 12:02 AM
Rpms Mustang RacR94 99-04 9 November 23rd, 2007 10:14 PM
