Intakes for a turbo 5.0
Old August 20th, 2011, 07:31 PM   #1
black5.0's Avatar
90 mustang notchback
black5.0 is on a distinguished road
Any suggestion for intake for a turbo 5.0? Right now i have ported E7s, ECam,bored 30 over, and 8lbs of boost. Im thinking about the holley system max or bbk ssi-r but im open to any other opinions . if you need any other info let me know. It will be more on the street than the track.
306 Turbo Notch D&G Tuned
1999 Chevy Silverado 5.3
Old August 20th, 2011, 11:07 PM   #2
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
edelbrock super victor EFI manifold, with a 90* elbow. thats when ill be running on my turbo 408 come spring time.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old August 20th, 2011, 11:24 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
stay away from the BBK ssi bull sh*t, ive heard they suck and have fuel leaking problems where the injectors go into the intake. Trick flow makes some good intakes lke there boxed intake or there R intake.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old August 21st, 2011, 02:38 PM   #4
black5.0's Avatar
I heard they leak from the crossover from the bbk rails, also im talking about the ssi-r which is a totally different design then ssi. Is the ssi-r having the same problems. The trickflow is 3000-8000 and its requires different rails.
Old August 21st, 2011, 02:40 PM   #5
black5.0's Avatar
Maybe your running a little bit more motor then me lol.
Old August 21st, 2011, 03:13 PM   #6
1992 Mustang Lx 5.0 347ci
11.8@115
SloMo is on a distinguished road
+1
Slow Motion... Quick reving, High compression, Big Boy 347 stroker... STROKER MOTION...
Old August 21st, 2011, 03:41 PM   #7
black5.0's Avatar
edelbrock super victor EFI manifold operating range 4500rpm-9000rpm seems kind of high for me.
Old August 21st, 2011, 04:25 PM   #8
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
IM Sticking with my cobra with a mild port.
Old August 21st, 2011, 04:46 PM   #9
fogged306's Avatar
89 GT
You're boosted. Those operating ranges won't apply to you. They really are only a guideline for that intake on a stock cube N/A engine. If anything do the systemax or a track heat. Those E7 heads are your choke point though and will limit the benefit of a new intake.
Old August 21st, 2011, 05:41 PM   #10
black5.0's Avatar
Yeah im going to eventually get a good set of heads. The track heat box or the regular track heat?
Old August 21st, 2011, 08:27 PM   #11
EscortSportage's Avatar
1989 Mustang GT 5.0
im running a track heat by TF, not the best for boost but i put down AMAZING numbers with stock cam.... u want to look into a carbd intake style with an elbow
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old August 23rd, 2011, 06:33 PM   #12
Notchthis is on a distinguished road
thats my plan as well! its also already on the car. the cobras can flow pretty well once ported!
'92 coupe 5.0/5spd cobra intake, b-cam, gt-40's, mac shorties, mac h-pipe, mac catback, cobra 5lug w/ 3.55's
Old August 23rd, 2011, 07:16 PM   #13
fogged306's Avatar
89 GT
Not with E7 heads he doesn't. Here's my supervic for a 302 next to a stock intake. Those intake ports are the same size as the intake ports on the E7 heads. Unless you pull the heads and do a lot of port matching, you don't want to put an intake that big on stock heads.
Old August 23rd, 2011, 09:42 PM   #14
uedlose's Avatar
89 Mustang
uedlose is on a distinguished road
I would not worry to much with a intake right now like said the heads are gone to be the main hold back even with a good intake. The turbo is gone to push the air through it anyway. If you want more power turn up the boost a bit. But if you must have one some of the edelbrock knock off stuff works well. if you are looking to save a few bucks. I have been pretty fast with a old edelbrock rpm intake with just the lower port matched to my heads. Keep the torque up down low and you will have a much nicer street car when off boost then when the boost comes on you have all the fun of a race car. What size turbo are you looking to run?
Just another turbo Mustang..No dyno numbers just good ets and MPH. And yes it is fast for a street car.
few parts for sale
https://docs.google.com/document/d/1...l=en_US&pli=1#
Threads Similar to: Intakes for a turbo 5.0
15% Off Air Intakes carid CARiD.com 0 August 17th, 2011 08:40 AM
Intakes boss302_gt 94-95 18 April 18th, 2007 09:06 PM
Air intakes? spero 99-04 15 April 6th, 2007 01:44 PM
99 v6 cam/intakes mmvi V6 Mustangs 21 February 24th, 2007 02:45 PM
