quick fox shock question...HELP IM CONFUSED LOL
Old August 21st, 2011, 09:20 PM   #1
VOGEL822 is on a distinguished road
Talking
sup guys on fox's there are 4 rear shocks...some there are two, are all four needed? did different years come with 2 and some with 4 ? thanks guys!!
Old August 21st, 2011, 09:40 PM   #2
1989 mustang lx
89lxstang5.0 is on a distinguished road
Send a message via AIM to 89lxstang5.0
the two horizontal shocks are called quad shocks, they help reduce wheel hop, alot of people remove them to fit bigger tires etc, generally u should have a good set of control arms before u take them off that way u dont wheel hop real bad.
Old August 21st, 2011, 10:04 PM   #3
great thanks bud i appreciate the help with these quad shocks removed would it cause the car to move left to right like as if you push on the car rock it side to side?
Old August 22nd, 2011, 12:43 AM   #4
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Just get some good upper and lower control arms and you can remove them. I'm in the process of replacing my control arms and I'm ripping those suckers out
Old August 22nd, 2011, 02:05 AM   #5
79Capri302's Avatar
1979 Capri GHIA
79Capri302 is on a distinguished road
my car didn't come with any but i agree, get better control arms and rip the quad shocks out
This is my story
Vid of car running
1979 Mercury Capri Ghia 5.0 T5 swap
Edelbrock RPM intake & 600cfm carb, E7TE heads, BBK equal length shorty hedders & off-road H-pipe, Flowmaster 40's, 8.8 swap with 3.08 posi
Project Info
Old August 22nd, 2011, 08:40 AM   #6
thanks! wth the quad shocks taken out would that cause the car to moove side to side if you push on it clunk clunk?
Old August 23rd, 2011, 10:12 AM   #7
banzaibullitt's Avatar
1986 Ford Mustang LX
banzaibullitt is on a distinguished road
No, they are only there to dampen wheel hop. The upper control arms are triangulated, and are the ones that help keep the axle centered.
If the axle is moving side to side, you better check your arm bushings for wear, and the chassis area for cracks where the arms bolt to the car
Old August 23rd, 2011, 04:47 PM   #8
ill crawl under it tonight and check i know the car is 100% solid it just seems like it pushes side to side more easy than it should for some reason...
Old August 25th, 2011, 02:16 PM   #9
any ideas what would cause the side to side clunk?
Threads Similar to: quick fox shock question...HELP IM CONFUSED LOL
Stupid question, but so confused bgroft281 99-04 1 August 8th, 2011 10:23 AM
shock install question 6ixer V6 Mustangs 2 July 9th, 2011 12:41 PM
HID Question PLZ HELP im Confused 02GT89 Visual 24 March 12th, 2010 10:49 PM
strut & Shock question mrbill4 2005 - 2010 6 May 22nd, 2009 12:44 AM
shock question mantis3567 99-04 2 December 20th, 2007 06:38 PM
