Big timin' in a small town
Hows this setup sound
Im going to build my motor this winter when im not driving it and heres the setup I was looking at
331 scat stroker kit ford racing GT40 or gt 40p heads any diference between the two? roller rockers gt40 intake or the cobra intake witch is better? mass air flow conversion and the next step bigger cam not any huge cam does this setup sound good im hoping to get about 350rwhp this sould do it shouldnt it |
Alright now I have two different heads what one better the tick flow twisted wedge or the ford racing gt-40x heads 64cc camber
You can buy nice aluminum heads cheap if you know where to look.
If you are going to spend the money AFRs are usually at the top of the list. |
1988 Mustang LX Turbo
i think i paid $1500 for my APR heads with no valves lifters etc, just a bare head
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Are the ford racing gt40x heads any good because I was not planing on spending that for bare heads the x heads are $1,100 come complete minus the rockers but im getting Harland Sharp roller rockers for that
also can I use the stock 19lb injectors with the setup listed |
i dont have much experience with the GT40 heads, but by reading around there really good heads to use and are worth a shot, and i would upgrade to 24lbers
#7 | |
#8 | ||
If you dont ever plan on running a supercharger or turbo make sure you have 10.5:1 to 11.0:1 compression. That will give you real nice numbers and will run on 91 or 93 octane without a problem...
Both heads are good. The Trick Flow would flow more and allow for a bigger cam. They would also need longer than stock push rods I believe. Stay away from the 40p's. They are good heads, but they require special headers because the plug is at an angle. Unless you are going to buy headers anyways that is. Also the plug is closer to the valve which limits upsizing them. Budget,go for the 40x's, don't care about an extra couple hundred bucks, go for the Trick Flows.
what kind of power do you think this would make over 400hp
I now what im going with the scat 331 rotating assembly trickflow twisted wedge heads 24lb injectors Cobra intake Harland Sharp roller rockers cloyes timing chain set hooker long tube headers and the mass air flow conversion |
#12 | |
Threads Similar to: Hows this setup sound
| Best Exhaust Setup (Sound, Power, Cost) | Kemp"Da_Chit"08GT | 2005 - 2010 | 25 | November 17th, 2007 11:22 PM |
| Hows this handling group sound for starters? | RyanHNT | 2005 - 2010 | 4 | July 19th, 2007 03:58 PM |
| hows this sound? | RC02GT | General Tech | 6 | July 6th, 2007 08:42 PM |
| Hows this sound? | Massie02GT | 99-04 | 16 | April 11th, 2007 09:26 PM |
| Hows The Setup Sound... | RC02GT | 99-04 | 6 | September 12th, 2006 05:51 PM |
