Upgrade help please!
Old August 22nd, 2011, 11:34 PM   #1
California69gs is on a distinguished road
This is my first fox body mustang. I recently bought an 89 mustang GT hatchback.
The motor has been rebuilt to stock specs but does have a cold air intake, headers, h pipe, and duel flowmasters. Stock auto tranny. The reared I got a great price on a completely redone 8.8 with 3.73 posi.
While collecting other pieces, when cheap, I've amassed a decent pile of stuff but need experience to finish my needs.
I have bought a trickflow 'R' upper and lower intake with spacers, underdrive pullies, aeromotive fuel regulator and fuel rails. And a lead on 24 lbs injectors tuned to an 88mm map?
I'm tearing down the fuel tank tomorrow to Sandblast and undercoat. Should I buy a high flow pump? Do I need a high flow return??
I'm looking for the right combo to tie this all together please. Or at least what to be looking for in the bargain shoppers area?
I'm hoping to build a city car that can put 300 horses at the wheels or better. For daily driving.
Thanks everyone!
Tj
Old August 23rd, 2011, 09:52 AM   #2
banzaibullitt's Avatar
1986 Ford Mustang LX
banzaibullitt is on a distinguished road
I'd go with at least a 190 fuel pump if you're going with 24 lb injectors.
Old August 23rd, 2011, 11:33 AM   #3
are 24lb injectors a good choice with this combination?
Old August 23rd, 2011, 11:43 AM   #4
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
yes
consider this.
Trick Flow Specialties TFS-K514-360350B - Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L - Overview - SummitRacing.com
you should also have a good shift kit and stall converter with that combo.
http://www.summitracing.com/parts/TRG-AOD-HP/
http://www.summitracing.com/parts/BMM-40431/
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old August 23rd, 2011, 03:09 PM   #5
That's kinda what I thought.
Do I need a high flow return if I get a high flow fuel pump and bigger injectors?
Old August 23rd, 2011, 06:15 PM   #6
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
24# injectors are free!!!! at the j/y. look for 4.6 L lincoln contanentles. front wheel dr makes it a 10 minut 4 bolt ordeal to get the injectors and put them in your pocket. $10-$15 bucks for new 0-rings and pintle caps and your good
Old August 23rd, 2011, 07:15 PM   #7
No, you don't have to mess with your fuel system at all except for a bigger fuel pump. I would also recommond an adjustable fuel pressure regulator. This is what I always use.
REAL Walbro 255LPH High Pressure Flow Intank Fuel Pump | eBay
Mustang 5.0 Adjustable Kirban Fuel Pressure Regulator | eBay
01 Ram Quad Cab
03 Grizzley 660
Old August 23rd, 2011, 07:21 PM   #8
fogged306's Avatar
89 GT
If you still have stock heads, don't bother with the injectors. You're not going to see anywhere close to 300 hp at the tires with E7 heads unless you have about 2k in portwork on them and a ton of other stuff.
Old August 23rd, 2011, 11:00 PM   #9
oh, yeah I do have stock heads. Well that sucks other people I talked to said that increasing my injector and fuel pump would put me in the 300's?
Old August 23rd, 2011, 11:01 PM   #10
cleangtvert, any special model I should be going after? That's the exact kinda deals i'm looking to find!
Old August 24th, 2011, 01:01 AM   #11
1989 Mustang GT
recore is an unknown quantity at this point
Look into a Lentech valve body for the aod, it will get back some of those 60 horses or so the stock tranny robs from the engine, and make it shift a crapload better.
Trying to be sensitive to the sensitivities of the sensitive regulars.
Old August 24th, 2011, 01:31 AM   #12
Is the lentech something that can be done easily by a shade tree mechanic or something that requires a complete rebuild?
Old August 24th, 2011, 01:33 AM   #13
lol, I just went from a 94 mustang v6 to my 89 Hatch V8. The thought of 60 horses being lost at the tranny is just funny. My V6 only made 130 to begin with!
Old August 24th, 2011, 05:58 AM   #14
1991 gt vert
lot of info here
Hotrod-Hell.Net : Ford Mustang Tech Article : Junkyard Warrior : A Guide To Free And Cheap Mods For Fox Mustangs
i have two sets. the continentles are super easy to get to the fuel rails
Old August 24th, 2011, 06:34 AM   #15
1989 LX coupe 5.0L
89lx is on a distinguished road
its not supper close but i have seen two stock headed cars put down 269 and 272.. e cams gt40 tub intakes 24lb injectors and bolt ons. the 269 car changed heads to eldelbrocks performers and put down 296
Old August 24th, 2011, 08:42 PM   #16
ryanw's Avatar
1991 Ford Mustang GT
if your going to upgrade your fuel pump, then just go with a 255lph. It will leave you room to grow
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old August 24th, 2011, 09:35 PM   #17
What kind of heads should I be looking for?
Better yet are my ideas of a 300 horses at the wheel even realistic. I don't want to run power adders or run anything higher than 87 regular.
Is that even reasonable?
Old August 26th, 2011, 04:56 AM   #18
So I can get a larger than needed fuel pump and it won't cause any harm?
Old August 26th, 2011, 05:42 AM   #19
Stdyhand is on a distinguished road
300 at the wheels is very reasonable. A good set of heads to go with that trick flow R intake should put you really close if not over your mark. A decent cam should help you get the most out of your heads, but I would choose them first.
Old August 26th, 2011, 07:36 PM   #20
ryanw's Avatar
you will be fine ( no damage)..any un used fuel just gets returned to the fuel tank
255 fuel pump,
3:27 gears
Threads Similar to: Upgrade help please!
Upgrade steve18 V6 Mustangs 12 August 11th, 2011 03:03 PM
Upgrade!!!! 69fastback The Clubhouse 6 December 14th, 2009 10:21 AM
MAF upgrade blueone 2005 - 2010 4 August 2nd, 2009 10:08 PM
GT upgrade night rider Classic Mustangs 2 March 20th, 2007 05:47 AM
upgrade kbblown99gt 99-04 3 January 4th, 2007 01:08 AM
