Wanting to build a stroker kit!!!! Got some ideas, wanted some feedback...
Old August 24th, 2011, 01:35 AM   #1
Look Ma! My First Post!
1995 Ford Mustang GT
15.00@115..
Smitty4469 is on a distinguished road
Thumbs up
Planning on doing a 347 stroker kit w/ 4130 cam, gt40 heads, cobra upper and lower intake, & chip it...
Need some idea's on a good size throttle body, fuel pump, injectors, mas/maf, and what kind of power i'd to expect....
I am running a aluminum drive shaft to a 31 spline axel, 3.73 gears, and solid rear upper and lower contol arms.....
Any help would be greatly appreciated...
Old August 24th, 2011, 01:36 AM   #2
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
I have gt40p heads if interested..
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old August 24th, 2011, 06:27 AM   #3
1989 LX coupe 5.0L
89lx is on a distinguished road
really it wont make much more power then a 302 with those mods.
my 347
80mm tb
30lb injectors
victor efi
3/8 spacer
afr 205 heads
trick flow stage 2 cam
with all the other bolt ons made 386hp and 376 tq. cams not the best for the car but i wanted to try it. i would say with the parts you listed 280-310hp
Old August 24th, 2011, 08:06 AM   #4
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
If you're going through the trouble of building a 347, I would put a decent set of heads, cam, & intake on it. I would say AFR 185/Twisted Wedge 190 at a minimum. Cam, Comp XE274HR or XE282HR, or Trick Flow Stage 2 or 3 or a custom grind. For an intake, Holley SystemMax or Trick Flow R, 75mm Throttle body, and 75/76 MAF minimum. You're gona need at least 30 lbs injectors and a good free flowing exhaust system. Also add a 255 in tank fuel pump!
The stuff you are mentioning is barly an upgrade for a 302 engine.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old August 24th, 2011, 08:37 AM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
What's a 4130 cam?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old August 24th, 2011, 05:42 PM   #6
skeletonpsycho's Avatar
1987 mustang GT
10.92@122
skeletonpsycho is on a distinguished road
agreed,with those mods you listed you would make more power with a single turbo on a stock motor
http://www.youtube.com/watch?v=gQ7g9ystpiU 347 all motor wawa pump gas driven everywhere
Old August 24th, 2011, 06:49 PM   #7
1 Wheel Peel
2000 Mustang 393w
Maybe he doesn't want a turbo?
2001 GT Vert
2002 Six Banger
Old August 24th, 2011, 07:22 PM   #8
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Well, if that's the case, he'd make more power if he saved his money on the stroker kit and bought good heads. A 302 with good heads will make way more power than a 347 with GT40s.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old August 24th, 2011, 07:35 PM   #9
1 Wheel Peel
2000 Mustang 393w
I'm not arguing that
2001 GT Vert
2002 Six Banger
Old August 24th, 2011, 08:30 PM   #10
ryanw's Avatar
1991 Ford Mustang GT
that intake and heads are to small for a stroker
id pick some thing like this
#1 Trick flow R or boxed intake
#2 Trick flow 185/190/205 cylinder heads
#3 80mm or bigger mass air meter and TB
#4 30-36lb fuel injectors
#5 I have no clue with the the cam
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old August 24th, 2011, 08:35 PM   #11
ryanw's Avatar
Heres my build.....its a vary long thread but alot of good info in it if you choose to read through it
331 stroker
255 fuel pump,
3:27 gears
Old August 25th, 2011, 04:33 PM   #12
'06 Mustang GT
richardhales is on a distinguished road
custom grind on that cam fo sho and def a good set off heads thats were the money is made i make 350 hp 374 torque with 75 mm throttle body, 30 lb injectors, pro-m maf trick flow high port heads, track heat intake, 1.6 rockers and a nitrous hp XR274HR cam but the cam and heads are def the bread and butter
Old August 29th, 2011, 02:51 PM   #13
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Lmao! A 347 with gt40 heads. Get some trick flow twister wedge 205 heads, Victor Jr efi intake, custom cam from bullet, crowed, flowtech induction etc., 90mm TB, lightning MAF, Anderson powerpipe and some 36/40# injectors along with 4:10s and walaa! Welcome to the 10s
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Threads Similar to: Wanting to build a stroker kit!!!! Got some ideas, wanted some feedback...
pics of possible new drag rims *feedback wanted** PapaSmurf Pictures 15 January 24th, 2011 05:34 PM
Build sheet, give me feedback beatup88lx 5.0 Mustangs 19 May 10th, 2010 11:13 AM
Wanting to build a 5.0, questions inside... _Andrew_ 5.0 Mustangs 13 May 4th, 2010 05:49 PM
wanting to build a 351 and need some help with advice and ideas mgrah87 Modular Mustangs 5 March 30th, 2010 04:26 PM
stroker kit ideas and help??? mustang95 5.0 V6 Mustangs 7 August 20th, 2009 06:38 PM
