steering wheel play
Old August 24th, 2011, 11:09 AM   #1
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
steering wheel play
i have some play in my steering , not much but enough to get on my nerves, i have ruled out the steering rack and the tie rods because they are both pretty much new, so i am going to go with a 03/04 steering shaft. I was just wondering how difficult this is to swap out, and is it a direct bolt in? Will i have to disconnect it from inside the car or does it unbolt before i get to the inside?
thanks guys
"my wheel bolts require more torque than your honda makes"
Old August 24th, 2011, 12:18 PM   #2
1995 Mustang GT Convert.
FAIL@PWR
NFChaos2003 is on a distinguished road
Why don't you get one of the MM steering shafts? I'm sure it would be numerous times better at getting rid of the play than anything stock.
Old August 24th, 2011, 06:46 PM   #3
1995 Mustang GT
Well because I hears that the cobra one uses needle bearings instead of the rubber one that ours uses, and I'm sure the mm shaft costs a pretty penny that I would rather spend on something else
Old September 1st, 2011, 02:14 PM   #4
EscortSportage's Avatar
1989 Mustang GT 5.0
check ur rubber steering rack bushings as well,
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old September 1st, 2011, 02:19 PM   #5
1995 Mustang GT
i will do that, i have decided im just going to go with the cobra shaft and be done with it, i hav heard that this shaft isnt a bolt on for the 94-98 mustang is this true?
Old September 1st, 2011, 02:24 PM   #6
1989 Mustang GT 5.0
no idea, im running a MM shaft, soon i will be running an 04 cobra steering RACK and the new MM hybrid shaft and MM aluminum steering rack bushings
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old September 1st, 2011, 05:17 PM   #7
50Droptop's Avatar
87 Mustang Lx
13.76@100
50Droptop is on a distinguished road
the rag joint is probably worn out...
Shawn
87 Coupe
The Notch
Old September 1st, 2011, 05:49 PM   #8
Isambard's Avatar
2001 V6 1990 5.0
Isambard is on a distinguished road
+1 on this. Easy to check and only costs about $13 for a kit to replace it. Just did mine a month ago. I still have loose steering in comparison to my 01 but I'm chalking it up to the power steering being slightly different.
Easy way to check is to get your wheel to lock after turning off the key and seeing if you can move the steering wheel more than an inch or so either way.
Old September 2nd, 2011, 05:58 AM   #9
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
brimmer555 is on a distinguished road
This is the one I got and put on my 89 GT. I gave it a 2 star rating on the site simply because I was pist with how difficult of a time I had getting off the old rag joint rig. But It really is a good part. but I still have play in my steering wheel. The play is between the firewall and the steering wheel some how.
anyway heres the link :
FR1504PLP MUSTANG FLAMING RIVER POWER STEERING SHAFT KIT 1979-1993
89 GT RESTO-MOD
http://www.youtube.com/watch?v=OWjkD...feature=colike
Old September 2nd, 2011, 09:49 AM   #10
1995 Mustang GT
yeah im not sold on exactly what im going to do yet, but i do know that highway driving on a windy day pisses me off, cuz the car drifts so much and trying to keep the wheel straight i feel like im turning the steering wheel back and forth more than i should. But the bad thing about that shaft is i have a 1995 gt. Idk if they were the same for that year or not. That does cost a pretty penny though and i def wasnt looking to spend that much to fix this problem
Threads Similar to: steering wheel play
Play in steering Dap1991 Classic Mustangs 4 April 17th, 2011 01:36 PM
Play in the steering wheel!! micah_14 96-98 2 June 16th, 2010 12:32 PM
Still Play In Steering Wheel weems 99-04 14 November 18th, 2009 08:37 PM
Steering Wheel Play and Sound SKRAPR 2005 - 2010 13 January 23rd, 2009 10:19 PM
Steering Wheel Play MaverickGT 94-95 9 October 16th, 2008 10:05 PM
