WTF is this sensor ???
Old August 25th, 2011, 12:15 PM   #1
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
alright well i have having some battery troubles, the battery is dead but i want to make sure all of the wiring is correct before i replace the battery, i am puzzled because this sensor in the pic has two wires, they are both going to the negative side of the battery, i dont know what the sensor is for so if someone could tell me and if i need it.? Also it seems like i have a lot of grounds up near the front of the car, i know the big one is for the battery but idk where the small one is coming from, i am just confused by all these wires coming from everywhere
here are some pics
"my wheel bolts require more torque than your honda makes"
Old August 25th, 2011, 12:21 PM   #2
1995 Mustang GT
if i had to guess i would say it was for the stock volt gauge on the gauge cluster, but why are both wires going to the negative battery post ? shouldnt one be going to positive and one negative ??
Old August 25th, 2011, 12:39 PM   #3
93 Mustang LX 5.0 5spd
N/A
easy-stangkin is on a distinguished road
I believe this is the ground connection that goes to your ecu...
Old August 25th, 2011, 12:50 PM   #4
1995 Mustang GT
oh alright, well there is two wires, where do they both go? right now they are both tied into the negative battery post as you can see in the pic. But wouldnt it make more sense for one of them to be grounded and the other one to be on the negative side? or does it matter?
Old August 25th, 2011, 12:50 PM   #5
1995 Mustang GT
it does run to the harness that goes into the fuse box under the hood by the way
Old August 25th, 2011, 01:35 PM   #6
1995 Mustang GT
ok well i got a little bit farther on this issue, i hooked the battery bag up with that sensor unplugged and the fan started constantly running, i plugged it back in and it stopped so i now know its there for a purpose but im still puzzled as to how to wire it up, there is two wires coming from this thing, do both go to the negative battery post? or does one go to the ground. but i think personally it doesnt matter because if i move it to the frame where the other ones are in the pic then its still going to be touching the battery ground wire coming from the front post, so it would still be the same thing as having them both hooked up to where they are now
Threads Similar to: WTF is this sensor ???
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2) Shaun03GT 99-04 23 March 19th, 2011 12:08 AM
MAF sensor norcal93fiveoh 5.0 Mustangs 2 August 4th, 2010 03:34 PM
bad O2 sensor? ddarkslayer 5.0 Mustangs 17 February 11th, 2010 07:31 PM
IAT Sensor 06dkkiser 2005 - 2010 V6 0 January 7th, 2010 01:54 AM
TPS sensor WNTS 2RN 99-04 3 October 3rd, 2007 08:58 AM
