Car runs...gauge says 0 PSI
car has had idling issues (no vac leaks, TPS is set, etc), so i decided to check fuel pressure to see if its losin pressure. hook a gauge to schrader valve, turn key on, 0 psi...start car, 0 psi. however, the car has plenty of power and runs fine.
thought maybe the gauge was bad...worked fine on another car immediately afterwards. tried mine again, same thing so, whats the deal? |
'06 Mustang GT
is any fuel coming out of the valve when you push on the nipple? if not the schrader valve is probably bad
yah...how much should
1991 Ford Mustang GT
Im also going to say that the schrader valve is probably bad. it may be a little bent to the side not alowing the gauge to push schrader valve in. I see this all the time with A/C system.
i thought that too, i removed the core out of schrader valve to allow it to openly flow out
could a hole in fuel line cause it to lose pressure but still have enough to run the car??? or is it more than likely gettin enough pressure and its just an issue with schrader valve?
have you ran your codes yet ? see if there are any fuel related codes that pop up. but i cant see a car running with 0 psi. my car ran like crap on 18 psi
fixed the problem...the core inside the schrader valve was broke, took one out of a tire and fixed it.
good to hear you fixed it. Your fuel pressure should be some where around 39 psi. But that is with the vacuum line pulled off the fuel pressure regulator. and the vacuum line caped
Threads Similar to: Car runs...gauge says 0 PSI
| She runs!! | naza | 99-04 | 85 | April 8th, 2011 01:02 PM |
| runs better without TPS.. | Chris951 | 5.0 Mustangs | 10 | January 6th, 2010 10:44 PM |
| It runs!!! | JBIGBOOTSY | 5.0 Mustangs | 9 | April 3rd, 2009 04:01 PM |
