1989 mustang gt
coolant line on 5.0 intake
There is a coolant line on my 89 5.0 intake manifold that goes from front to rear and tees off to the egr spacer, can this whole line be capped off with out any cooling problems? I am really sick of looking at it .
1991 Ford Mustang GT
yes....it cools down your EGR spacer from the exhaust gasses....if it still works, just leave it. I dont have mine hooked up
#3 | |
if your EGR is still working/connected leave the lines on... to block them off you will need 3/8" NPT (Male Plug)... |
Threads Similar to: coolant line on 5.0 intake
| PI intake swap Coolant Temp question | Ruffellbaker | 96-98 | 5 | June 8th, 2011 12:20 PM |
| Coolant leak at intake | donlocke65 | 99-04 | 4 | November 12th, 2010 12:33 PM |
| Coolant Leak and Intake Manifold | rewadferger | 96-98 | 12 | September 5th, 2009 10:34 PM |
| water crossover on intake manifold leaking coolant | hardhitter | 99-04 | 10 | January 5th, 2009 02:39 AM |
