smelling gas
Old August 27th, 2011, 03:23 PM   #1
90 notch is on a distinguished road
smelling gas
soo I jus bought a chilton manual and it sucks. Diagrams only and it dsnt show where the tb or intake is in anything. I've found 2 vacuum lines that don't go anywhere. One is from the back of the intake and directs toward the egr. I smell eye peeling gas being burned. I know the egr has some issues which is why it idles as tho I have a cam. I have after market headers exhaust and deleted the air pump. Help?
Old August 27th, 2011, 03:49 PM   #2
fogged306's Avatar
89 GT
Whenever you have excessive fuel being dumped, it will make the idle more choppy. I can take my car from a smooth stock-like idle, to a choppy idle with just tuning the amount of fuel being added at idle. I would start with checking your fuel pressure and then if everything looks ok, checking for codes next. Do you still have stock injectors and a stock MAF?
Old August 27th, 2011, 05:26 PM   #3
00MustangGtPremium's Avatar
2000 Mustang Gt
no clue
00MustangGtPremium is on a distinguished road
Vacuum leaks can also make a car seem like its cammed
Just because your cars loud doesnt mean its fast
Old August 28th, 2011, 03:54 AM   #4
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
if you got rid of the pump did you block off the holes on the headers? that may be one reason why you can smell the gas too??
have a quick check under the rear of the manifold there is a small vaccume tree feel around and make sure there are pipes connected to all the little spouts underneath...
these may help if you can follow the diagrams :
http://www.veryuseful.com/mustang/te...uumDiagram.jpg
http://www.veryuseful.com/mustang/te...g5.0Vacuum.gif
Old August 28th, 2011, 08:02 PM   #5
I plugged everything off yea. And the codes seem ok. It has stock maf and I think injectors. But I noticed the injectors are yellow tops. Aren't those 24 pound? If so maybe it's too much for stock intake and such.
Old August 28th, 2011, 08:03 PM   #6
btw I noticed the smell when I ran 90 octane with fuel injector cleaner. I have yet to change the fuel filter.
Old August 28th, 2011, 08:07 PM   #7
fogged306's Avatar
89 GT
Are you smelling the gas though the exhaust or is it coming from the engine bay?
Yellow tops are 19# just like the factory orange ones that came on these cars.
Old August 29th, 2011, 01:23 PM   #8
ok cool. I'm smelling it between the motor and firewall but out of the exhaust itself is 10xs worse. Eye peeling strong
Old September 2nd, 2011, 01:53 PM   #9
I hvnt changed my fuel filter since the last fuel injecto cleaner. Also I have been using 90 octne fuel. Could any of these contribute to the problem?
Old September 2nd, 2011, 05:06 PM   #10
fogged306's Avatar
89 GT
The 90 octane isn't going to do that. The fuel injector cleaner may be the culprit though. It may have removed some deposits on the fuel line or injector itself and moved them into the moving parts of the injector and caused it to stick open. I would pull the plugs one by one and see if any look wet with gas or fouled out. If you find some like that, then the injector for that cylinder is probably gummed up.
Old September 2nd, 2011, 08:55 PM   #11
50Droptop's Avatar
87 Mustang Lx
13.76@100
50Droptop is on a distinguished road
Id clean your maf sensor.. if its dirty or has oil on the sensors from a oiled air fliter like a K&N it can cause it to run rich. If you deleted the charcole canister and left the vent line hanging it will send fumes out too.
CHeck your fuel press as well.
If you deleted the air pump did you cap off the line going to the h pipe?
Shawn
87 Coupe
The Notch
Old September 4th, 2011, 11:18 AM   #12
I capped off the lins from the ir pump. I did oil the filter not too long go so I'll check the maf nd replace the fuel filter. Then hen I get extra time I'll pull out fuel injectors. I also need a fuel pressure gauge..shoulda kept the one off my t/a :/
Old September 4th, 2011, 11:26 AM   #13
50Droptop's Avatar
87 Mustang Lx
13.76@100
Sounds like a good place to start. Let us know if it helps.
Shawn
87 Coupe
The Notch
Old September 5th, 2011, 08:22 PM   #14
well the fuel filter was dirty but it wasn't the prob. I'll try the vacuum lines next with the maf tomorrow and let you kno.
Old September 6th, 2011, 03:08 PM   #15
95Slobra's Avatar
1995 Mustang Gt
95Slobra is on a distinguished road
jus a pointer as well. our cars seem to have a problem with the gasket that goes from the gas tank to the neck. one day when i filled up i woke up the next morning and smelled gas in my bedroom!! the gasket was bad and its normal supposly. just a heads up if u smell gas and your engine bay is fine
Threads Similar to: smelling gas
smelling gas/fuel SON1C 99-04 17 June 6th, 2011 10:04 PM
Smelling coolant, but no leak? ViperGT 99-04 9 February 4th, 2011 12:38 PM
Started smelling fuel??? 93HatchsBFF 96-98 9 August 24th, 2010 08:51 PM
So i have been smelling gas lately? 93HatchsBFF 99-04 8 February 4th, 2010 11:18 AM
Smelling Gas cbrown 99-04 14 September 18th, 2007 04:47 PM
