what rearend should i use?
I got a 91 gt convertible that i am building a 347 stroker for and i need to upgrade my rearend about the same time that i put the motor in it. anyone have advise as to which rearend i should put in there?
just rebuild your 8.8 you wont make enough power to hurt it
it is actually going to be drag prepped and pushing about 650 hp. that is why i want a good aftermarket one. i don't want to fry it and be screwed and not have my car for a while.
might as well go all out and get the ford 9 inch...you wont ever regret gettin the best....
the only thing is that i heard that the 9 inch is good but a 8.8 is just as good and it doesn't weigh as much. i kind of want to get an aftermarket one but i just want to hear some other peoples advise on what one to get. thanks.
I don't believe that an 8.8 is as good as a 9inch.
1987 Ford Mustang GT T-tops 14.33 @ 99.19mph on a 160k mile motor.
that is just one of the things that i have heard. didn't know if it was true or not.
In my opinion, there is no reason to put a 9 in in a mustang that already has a great rear end. There are a lot of people putting down huge torque numbers with an 8.8 and no problems.
Put new axles, bearings, diff and diff girdle in there and she'll be plenty good to 650 hp. No reason to replace the housing, they last forever...until they break. Most aftermarket rears use original housings anyway.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
how much do you think all that would run? it has limited slip and i kind of wanted to put posi in it. there are also 3.73 gears in it but what else would i need to upgrade? I don't know much about rearends i am mostly know about the motors and suspensions.
#10 | |
all motor
92 coupe
9.94@136.40
get a posi unit or a spool( I have detroit locker) but a lot people run spools, new axles, i would recommend strange engineering's axles prolly 31 spline i think it is, and you can keep your 373 it would be prolly good with that much hp depending on your taste
#12 | |
89 GT
+1230123234098
get a notch if you want a drag car. The lighter the car the faster it will run with the same power. I never can figure why people always make convertibles drag cars, you are already starting with a disavantage. |
sell the vert buy a hatch,a notch is to noce of a car to make into a drag car.keep the 8.8 put a set of 33 splines or better a mini spool, upgrade the axle studs and carrier.then be happy cause u just saved a lot of money.then spend the money u saved to buy a block so you dont do without your car for a while and throw your money down the drain.as far as the 9 being to heavy shot gun bore the axles you will save about 15lbs per axle if u use the big heavy duty axles like i did (44 spline).
#15 | |
Diff or spool $150-$500 depending on what you want (spools are cheaper) girdle and bearings $150-200 The cheap and easy way to go is to do a performance trak-loc rebuild (replace the 3 clutches with 4), upgraded 28 splines, and a diff girdle. Altogether that should cost you $400 or less and you can do it all yourself no problem. That is basically the set-up I have on my 88 that is putting down 400 hp to the wheels. It will last a long time on the street, sticky tires at the track might be a different story. |
#16 | ||
Why do all you guys try to doubt on all other peoples shit. all i am trying to do is get some opinions on what rearend to use. you guys can think all you want about it and you will just have to see. i will post the dyno results when i get them. all i want is some peoples opinion on a rearend.
#18 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
I would trust the 8.8 up to 400 hp. after that I would go 9 inch bullet proof
#19 | |||
ya i may just stick with a 8.8 and posi it and do all the upgrades that i can and i am going to switch to the 5 lug soon. thanks ryans88gt.... you are about one of the only helpful people so far. some people just don't get that you got to work with what you got. and some people dont have the money to just go out and spend all the money they want and get anything. i know i don't. that is why i want to get as good of stuff as i can the first time so i don't have to keep replacing it.
Threads Similar to: what rearend should i use?
| What rearend does my 89 gt have | White 89 | 5.0 Mustangs | 5 | October 4th, 2007 04:56 PM |
| Rearend ?? | Stang6899 | V6 Mustangs | 6 | September 21st, 2007 06:47 PM |
| rearend-tranny ? | theyanks904 | V6 Mustangs | 130 | August 15th, 2007 06:29 PM |
| 9 in rearend? | solareclpse2000 | 5.0 Mustangs | 7 | January 9th, 2007 09:25 AM |
| Rearend | thewayshemoves | 99-04 | 6 | December 27th, 2006 11:31 AM |
