DSS 331 Stroker HP
LinkBack (1) Thread Tools
Old August 27th, 2011, 08:56 PM   1 links from elsewhere to this Post. Click to view. #1
ADavis40's Avatar
1989 Mustang gt
ADavis40 is on a distinguished road
DSS 331 Stroker HP
Hello everyone I was needing your input on how much horsepower you think this setup would have on this engine. The engine is a pro billet 331 stroker from Dss racing, the engine has comp cams and the lift is .565/.574 232/240 the block also has 205 cc AFR heads, 1450 CAMSHAFT, push rods: 4130 .80", CAMSHAFT: Ford racing, TIMING CHAIN: Pro gear 3 position double roller 430HDSTK LIFTERS, PUSHRODS: 4130 .80, Dss Aluminum Roller Rockers. Also the engine was balanced and blue printed. If you need any more information just let me know, and I will try my best to answer them.
Thanks for all replies
Old August 27th, 2011, 10:00 PM   #2
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
I'd say 475+ flywheel isn't out of the question.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old August 27th, 2011, 10:44 PM   #3
ADavis40's Avatar
1989 Mustang gt
We was wandering could we get 400 hp to the rear wheel?
Old August 27th, 2011, 11:13 PM   #4
94 GT
13.95@100
furreal302 is on a distinguished road
can i have your engine?
94 Opal Frost GT ~230k
T5 swap, other mods
Old August 27th, 2011, 11:17 PM   #5
ADavis40's Avatar
1989 Mustang gt
Heck no lol.
Old August 27th, 2011, 11:29 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
What rpm are you taking it and what compression? Assuming 9.0 and 6250...
A 331 with AFR 205's, 330-370 RWHP.
Take it higher and more power.
Old August 28th, 2011, 11:30 AM   #7
ADavis40's Avatar
1989 Mustang gt
To make max power it redlines at 65000 rpms.
Old August 28th, 2011, 12:41 PM   #8
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Take the cubes and go for the 347. And what is a 1450 camshaft?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old August 28th, 2011, 01:01 PM   #9
ADavis40's Avatar
1989 Mustang gt
I will be honest man, this is my unlces engine he has had it for alittle while now and I was just putting down the information from the paper from dss, he was just wandering how much hp he should be looking at to the ground.
Old August 29th, 2011, 02:28 PM   #10
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
To the ground? Ask what compression he is at and we'll assume you're spinning it to 7,000...probably 380 to the tire.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old August 29th, 2011, 06:07 PM   #11
ADavis40's Avatar
1989 Mustang gt
Intake: Holley System Max
Compression: 10:9:1
Exahust: Flow master super 44's 2 1/2 inch
Camshaft: Comp cams .565/.574
Also the engine has the following. Bbk shorty headers, 70 mm Throttle body, 24 ft/lb injectors, 4:30 gears, Adjustable fuel pressure regulator, 208/160 valves and a zex nitorous kit that is 75-125 dry shot that is not hooked up yet. Also on the injectors do you think that we should get a bigger set of injectors, or just leave them the same? He is hoping to get 400 hp to the ground on motor do you all think it is possible with this current setup? Also if you all have any more questions be sure to ask.
Old August 29th, 2011, 08:29 PM   #12
Compression: 10:9:1
IMO, the BBK shorties, 70mm TB, & 24 lbs injectors are going to all be too small for this set up. 1 3/4" long tubes, 75-80mm TB, & 30-36 lbs injectors would be a much better set up. Why have those high flowing heads and choke them off with small 1 5/8" headers & 70mm TB?
01 Ram Quad Cab
03 Grizzley 660
Old August 29th, 2011, 08:57 PM   #13
ADavis40's Avatar
1989 Mustang gt
He just got married has not had enough money lol.
Old September 3rd, 2011, 03:26 AM   #14
1SICK5.0VERT's Avatar
modded 95 gt vert
1SICK5.0VERT is on a distinguished road
Originally Posted by nolife View Post
what rpm are you taking it and what compression? Assuming 9.0 and 6250...
A 331 with afr 205's, 330-370 rwhp.
+1 totally agree with those numbers
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
Old September 3rd, 2011, 03:35 AM   #15
modded 95 gt vert
Originally Posted by adavis40 View Post
intake: Holley system max
compression: 10:9:1
exahust: Flow master super 44's 2 1/2 inch
camshaft: Comp cams .565/.574
also the engine has the following. Bbk shorty headers, 70 mm throttle body, 24 ft/lb injectors, 4:30 gears, adjustable fuel pressure regulator, 208/160 valves and a zex nitorous kit that is 75-125 dry shot that is not hooked up yet. Also on the injectors do you think that we should get a bigger set of injectors, or just leave them the same? He is hoping to get 400 hp to the ground on motor do you all think it is possible with this current setup? Also if you all have any more questions be sure to ask.
id get rid of the shorties and run a set of longtubes. Shorties dont do much for hp anyway. As for the injectors id run nothing smaller then 30 ft/lb injectors because youll be needing them. With the 24's youll have to crank your fuel pressure regulator all the way up and you will probably run out of fuel by 350rwhp if that.
Old September 5th, 2011, 08:37 PM   #16
ADavis40's Avatar
1989 Mustang gt
He can not have long tube headers, because of the lakewood bell housing it will not clear it. He is wanting to have 400 hp to the rear wheels just on motor, he said that he would try to get some bigger injectors he is thinking about 36 ft/lb is that too much or just about right? Also what brand would you be looking at for the injectors and would you recommoned getting a bigger throttle body? If so what size would you be running? Thanks for the help.
Old September 5th, 2011, 09:20 PM   #17
1995 Mustang GT
Bubba95SN is on a distinguished road
Use Comp Cam Desktop Dyno.
Old September 6th, 2011, 01:23 AM   #18
BassMaster5000's Avatar
'90 Mustang GT
BassMaster5000 is on a distinguished road
I've got 342/364 to the wheels out of my most recent dyno tune, with a similar 331 stroker set up.. Like everyone else has said, run a bigger throttle body and some longtubes.. there are longtubes that fit around the lakewood bell housing. Kooks for instance are high in price, but some of the best headers you can buy, and will fit your application.
90 Gt- 331 Stroker, Forged Internals, TW Ported Heads, 30# Injectors w/ adjustable Kirban Fuel Pressure Reg, CI Custom Cam, Holley Systemax, 70mm Accufab TB, 75mm ProM MAF, BBK Fenderwell.
Dyno'd at 342/364 best E.T. is 12.8/109.
Old September 6th, 2011, 04:15 PM   #19
ADavis40's Avatar
1989 Mustang gt
Is there any other brands that you know of that has long tube headers that would work on the lakewood bell housing? Also would it be alright to run a 75 mm throttle body or should he go with a 80 mm throttle body? Also what would be better on the injectors, 30 ft/lb or 36 ft/lb and what brand would you all recommoned? I think he is wanting to run the zex nitrous kit so I figured that I would say the 36 ft/lb injectors with the 80 mm tb should be good enough? Also if he changes injectors, throttle body, and long tube headers how close would he be to 400 rwhp or could he even reach this on motor? Thanks for all the help.
Old September 6th, 2011, 05:58 PM   #20
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Lol...for what?
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/231330-dss-331-stroker-hp.html
Thread FEELER DSS 5.0 2v Stroker Kit | Corral.net: Ford Mustang Forums | BoardReader This thread Refback January 28th, 2012 06:26 AM
Threads Similar to: DSS 331 Stroker HP
408 stroker -Joeyy- 5.0 Mustangs 53 October 29th, 2008 08:25 AM
298 stroker 05roush0090 2005 - 2010 52 October 21st, 2008 08:31 PM
stroker 95BlackStang 94-95 29 September 27th, 2008 11:53 PM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 10:46 AM
331 stroker vs 302 mustangfox9091 5.0 Mustangs 3 September 20th, 2007 02:17 PM
