Push Rod quiestion?
Old June 1st, 2006, 12:20 AM   #1
Mustang8719 is on a distinguished road
Push Rod quiestion?
I am going to be installing a Ho Cam and lifters into a Non-HO block.
Removing the flat tapped lifters and installing roller lifters with the Cam.
The quiestion is are the Pushrods the same between the Flat tapped lifters and the rollers?
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Old June 1st, 2006, 01:06 AM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
are you not looking for a lot out of the cam??? or is one of the roller grinds that much to your liking?? just curious btw. pushtubes i believe are different length, but someone here will know for sure
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old June 1st, 2006, 09:44 AM   #3
they will be different.
88 Mustang Coupe
www.rickscarcare.net
Old June 1st, 2006, 12:48 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Get a pushrod measuring tool.
Old June 1st, 2006, 07:33 PM   #5
I an running a Ho enigne in the car out of a Grand Marques.
Want to install the Stock Cam from a Ho and have the engine a HO.
Thanks for the reply's I will get it all figured out.
Old June 1st, 2006, 11:17 PM   #6
ok...cuz a non roller block has to be modified for a roller cam, with a retainer kit for the followers....
Old June 1st, 2006, 11:45 PM   #7
Finding that out slowly.
Who ever said it was easy!!!
LOL
Anyone know the Spec's on a stock Cam?
Threads Similar to: Push Rod quiestion?
Well damn it...push the nine what you say....ya..ya..ya WAR-PARTY The Clubhouse 9 August 10th, 2007 10:34 PM
99-04 push start? energiesource 99-04 32 August 2nd, 2007 04:46 PM
Stock Cam Quiestion? Mustang8719 5.0 Mustangs 5 June 26th, 2006 08:15 PM
Throttle Body quiestion? Mustang8719 5.0 Mustangs 10 May 27th, 2006 05:12 PM
Battery relocation quiestion? Mustang8719 5.0 Mustangs 13 May 2nd, 2006 12:08 AM
