vortech street boost kit?
Old August 29th, 2011, 03:28 PM   #1
88gt_5.0's Avatar
1988 mustang gt
n/a
88gt_5.0 is on a distinguished road
Send a message via AIM to 88gt_5.0
will a 24lb injector support this system? Mustang Vortech Street Boost Supercharger System - Satin (86-93 5.0L) at AmericanMuscle.com - Free Shipping!
88GT_5.0
Old August 29th, 2011, 03:48 PM   #2
fogged306's Avatar
89 GT
Probably work with the FMU that comes with it if you kept the stock pulley on. If you wanted to do it right, I would do 30's (or larger) and a tune or tuner. Keep the AFR a little richer at WOT like boost likes and keep the duty cycle of the injectors down. An FMU will cause the injectors to operate at a higher PSI/dutycycle and will shorten their lifespan.
Old August 29th, 2011, 06:25 PM   #3
Dap1991's Avatar
91 GT 90 LX 5.0
Dap1991 is on a distinguished road
only 2k, i always thought they were more, is their options down the road to swap pullies and make more boost eaisly? or is that about it for that specific unit? Will they run without a tune or is it pretty necassary
1991 GT- All Stock
1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs
Old August 29th, 2011, 06:46 PM   #4
1987 GT
13.19 @ 107.02 (street tires)
chrisbmx is on a distinguished road
I bought this exact kit last year. Very happy with it. Spins through 1st and 2nd on street tires (fun but sucks for ET). I have full length sfc's ready to install and am getting stickier tires to fix it a little.
I used 30# injectors because I got the maf, injectors and adjustable fpr for $150. If I didn't get this deal I would have got 42#'ers. I have to run the 30#'ers at higher psi, about 50psi (not sure if this is the right number, it's what the gauge says when I'm cruising down the road, not with the vacuum line off, etc.) to get the a/f ratio around 11.5-12 (safe level). I didn't get a tune and it runs fine. I'm sure a tune would run better.
Yes, you can buy pulley kits for these (vortech.com) and in a year or so, I plan to get the kit with a 6.87" crank pulley and 3.12" blower pulley for about 3-4 more psi. At the same time, I'll upgrade the injectors to 42's. Any more boost than that, you will need a bypass valve from what I've read.
Make sure to get wideband O2 sensors with a gauge. Very important to know a/f when boosted. Should also get a larger fuel pump if you haven't already.
I was advised against using the FMU from the forum from guys that know much more than me and it's still sitting in the box.
Old August 29th, 2011, 07:42 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
I have an FMU and a BTM and make some decent power. Not an ideal solution but it works. You can try the FMU with your 24's for a while and if you can't or do not want to self tune or find someone willing to tune if with the FMU, chuck it and get 42's, and a 42 calibrated MAF.
Threads Similar to: vortech street boost kit?
Vortech supercharger possible boost lost? 04mach1vtech 99-04 19 April 18th, 2011 07:35 AM
Upping boost from 5 psi to 12-15 psi on vortech v1 Moot88 5.0 Mustangs 11 March 15th, 2011 11:42 AM
Calling all Vortech owners (boost q) Alter Ego Trip 2005 - 2010 0 May 30th, 2010 04:48 PM
Vortech boost ? red92droptop50 5.0 Mustangs 22 June 8th, 2009 04:57 PM
vortech pulley size? boost? belt ? faststang General Tech 20 August 26th, 2006 09:17 PM
