no gas gauge please help me
i have an 87 convert the gas gauge doesnt work how can i fix this? also i have a 91 ranger with the same prob ne help i would appreciate thanks
Probably need a gas level sending unit.
Yeah, it is probably your sending unit. Pull your fuel pump outa the tank and check the float and all the wiring for lose wires. If you have a voltmeter, you can check to see if you have any change in resistance while you lift and lower the float. Or just replace it and pray that it is the problem.
Big timin' in a small town
I had the same problem with my 87 bronco II it ended up beiging the float on the sending unit wasnt floating anymore the solder on it began to leak and the float just sank to the bottom of the tank and never read any gas level
#5 | |
#6 | ||
Threads Similar to: no gas gauge please help me
| gauge set up | joe 5.0 | 5.0 Mustangs | 8 | May 17th, 2007 08:12 PM |
| A/F Gauge | ujslost | Modular Mustangs | 17 | May 5th, 2007 11:41 PM |
| Gauge Pod | mb03stang | 99-04 | 4 | April 3rd, 2007 03:02 PM |
| Gauge help! | dblindberg | 2005 - 2010 | 11 | February 7th, 2007 10:39 PM |
