1988 LX
help quick!!!!running isue!
hi i have a 1988 lx speed density and just yesterday out of nowhere i noticed the cars response and behaviour was being wierd, if i keep my foot steady on the pedal and im steady around 2500rpm i feel alittle bogging and hesitation, at WOT the car still beasts it out but theres alittle different feel to it, it was also idling slightly wierd but idle went back to normal after warm,could it be my tfi module?
mods: offroad h-pipe to flowmasters,pullies,bbk intake,bbk shorty headers,frame connectors, thank u in advance |
Did you just buy gas? If so you may have gotten some bad gas. Otherwise maybe the coil, plug wires, distributor cap/rotor even a plug that went south. Just some simple things to check.
1990 LX 5.0 2000 Expedition 2002 Honda Accord One tea cup Chihuahua guard dog!!!!!!! |
1988 LX
no it was almost empty wen it started and i just got a coil about a month ago,how would i go about checking the wires or the cap/rotor?sorry im semi new to this..also i took it out for a spin again and 1st gear was pretty normal but 2nd i had maybe 2/3 power then i got to about 4000rpm and all the power came back,so i continued to 3rd and back to 2/3 power followed by some wierd sound from my engine,sounded like sparking or igniting maybe 1 sec apart:s
thank you for ur input its appreciated! |
If it was almost empty then theres your problem. The gauges vary and are optimistic in these cars. Id say its low of fuel (out). The dist cap can be pulled by the 2 clips and inspect. If its the orginal then go buy a new cap, rotor,plugs and plug wires. Make sure you get the firing order back correct,13726548. Looking at the motor number one is on the right side (passenger side) first cylinder and goes 1234 front to back then the left side is 5678 front to back. My car will show 1/16 of a tank and in reality is out of fuel. Hope this helps.
1988 LX
thank you ill try out wat u suggest and get back to u !
1988 LX
ok so i cleaned some stuff up stiffined up a loose battery connection and still the same,but now it almost always is 100%on WOT but still wierd
Threads Similar to: help quick!!!!running isue!
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| Car running hot, need quick help! | carney | V6 Mustangs | 22 | July 21st, 2011 06:31 PM |
| 2002 gt not running??? had multiple missfires not running!! | foxcruzin91lx | 99-04 | 8 | July 20th, 2010 03:00 PM |
| Meguiars Quick deatailer.. or Ultimate Quick detailer?? | svtkidd23 | General Car Care & Detailing | 12 | January 26th, 2009 12:23 AM |
| alright quick quick light tint question | thorpedo26 | The Clubhouse | 18 | September 1st, 2008 07:36 PM |
