Just an FYI on Power Steering system
Old September 1st, 2011, 09:00 PM   #1
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
For those of you who have remanufactured pumps and racks from autozone or advance etc... DO NOT put automatic transmission fluid in them. Found this out the hard way. The parts that are original from Ford is okay but the seals that are in the new ones are not made for atf. The atf will destroy the seals and possibly the pump, havent got to the pump yet, just got done replacing the rack today with a new one under autozone warranty. I flushed the system out before i hooked the lines up to the pump and after. I went through 2 quarts of power steering fluid until i stopped seeing red coming out. got under the car today and the boots were full of atf fluid, and the rack isnt that old. so maybe a new rack will cure my whining problem, if it doesnt ill prolly replace the pump and this fill it with power steering fluid. Well anyways just throwing this out there for anybody who is interested.. laterzz
"my wheel bolts require more torque than your honda makes"
Old September 1st, 2011, 10:02 PM   #2
50Droptop's Avatar
87 Mustang Lx
13.76@100
50Droptop is on a distinguished road
tough lesson to learn...
I have always just used PS Fluid in the PS
Shawn
87 Coupe
The Notch
Old September 1st, 2011, 11:57 PM   #3
1995 Mustang GT
Yeah it is but At least it didn't cost me any money..the thing that is really misleading is the parts that are on the car from ford is what calls for ATF but since the re man ones are built with different seals it's a no go..prolly gonna have to change the power steering pump too , and it has a lifetime warranty too, can't really go wrong with the warranty lol
Old September 2nd, 2011, 11:53 AM   #4
2006 GT
11.99@114
1LOUDGT is on a distinguished road
Why would you put transmission fluid in the power steering to begin with?
2006 GT (Fastest)
2004 COBRA (Faster)
1990 LX 5.0 (Fast)
Old September 2nd, 2011, 12:30 PM   #5
1990 Mustang GT
Stevo077 is on a distinguished road
Lol I warned you! At least you had a warranty on it.
1990 Mustang GT
Old September 2nd, 2011, 01:19 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
Because just about every Ford calls for ATF to be used, either Type F, Mercon/Dexron, or Mercon V depending on the year. I don't have my Fox owners manuals in front of me verify which one but my guess is Type F (someone have a mnaul handy?). I'm surprised someone blamed your seals on you using ATF. ATF is functionally equivalent in compounds to conventional power steering fluid. If it was anyones fault, it is the rebuilder, they either did a really crappy rebuild or used the wrong seals and the guy behind the counter taking your return is just ass-uming. Honda is the only oddball on that requirement, they have a very specific type
of PS fluid that has to be used.
Offtopic but to add to the confusion, Ford now suggests that all PS systems that were using Mercon/Dexron should now use Mercon V with some exceptions (TSB) and the systems that required Type F should still use Type F.
Old September 2nd, 2011, 10:26 PM   #7
1995 Mustang GT
x's 2 ^
Old September 3rd, 2011, 05:58 AM   #8
2006 GT
11.99@114
Learn something new every day.
2006 GT (Fastest)
2004 COBRA (Faster)
1990 LX 5.0 (Fast)
Threads Similar to: Just an FYI on Power Steering system
Help with power steering to manual steering conversion Alucard2008 94-95 3 April 20th, 2011 06:12 AM
power steering to manual steering swap necro5.0 5.0 Mustangs 14 March 25th, 2010 10:57 PM
What kind of steering system does the 88 have? dr.gonzo! 5.0 Mustangs 6 August 5th, 2008 01:43 PM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
Power Steering?? RedHott66 V6 Mustangs 2 December 22nd, 2006 06:17 PM
