leaking differential fluid
Old May 21st, 2007, 10:56 AM   #1
cobralini is on a distinguished road
I had a shop change my diff fluid and now it leaking. At first I thought is was coming from the cover but when I looked under it appears to be coming from the end close to the driveshaft.
Is the fill plug on that side? If they over filled it will it run out on that side? What could be the problem?
Old May 21st, 2007, 12:40 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
the fill plug is on that side but if the plug is tight it shouldnt leak out of it
Old May 21st, 2007, 01:09 PM   #3
Yea, I have to check it. It must be loose and hopefully not stripped.
Old May 21st, 2007, 01:14 PM   #4
Drick's Avatar
Thats what I would do just check and see if its tight if it striped then that would be bad
Old May 21st, 2007, 02:35 PM   #5
ryans88gt's Avatar
If its overfilled it will leak out of the passenger side vent on the axle tube itself. The fill plug is on the driver side of the front of the housing. Its a pipe fitting plug, so a little teflon tape or other sealant never hurts.
Threads Similar to: leaking differential fluid
Differential 01dutchGT 99-04 15 November 12th, 2007 01:37 PM
Help! Differential flames_blue V6 Mustangs 5 February 5th, 2007 03:55 PM
Differential whitb610 99-04 5 November 4th, 2006 10:49 AM
Welded Differential? flattusmaximus78 V6 Mustangs 6 October 12th, 2006 07:52 AM
Differential Drgnracin72 General Tech 4 September 19th, 2006 10:06 PM
