1991 mustang 5.0
Temp question
Where should the temp gauge read normally? My 88 always read down at the bottom of the gauge but I know it was wrong lol. But my new 91 always has the needle pretty much exactly on the middle line sometimes just a little lower when its warmed up. Is that normal? I guess if my gauge is correct that middle line is technically 200 degrees.. but sometimes when I do more city stop and go driving it gets warmer. When this happens it gets about 3/4's up the gauge and one time it got to the line before the red. Why would this happen? It has a new single row aluminum radiator, stock fan and fan shroud, and it has coolant. Its just weird because it doesn't always happen in traffic either. Just once in a while. And highway driving it always stays on the middle line so it just happens when idling at stop lights pretty much but not all the time. Any help would be appreciated. Thanks guys
1993 mustang gt
stock
My 93 gt stays in the middle i say thats normal idk about goin almost to the red though only time mine went past half is when i found out i had a pinhole in my radiator
1991 gt vert
the stock guages are known to be a joke! i have no idea what the actual temp sweep is on theese guages since it just says NORMAL, but the middle should be ok.i'll be putting in a 3 guage A piller pod in mine soon . narrow band a/f,water,and oil. plus i just ordered a new tack (recent thread on that).
89 GT
1991 gt vert
^^ i know,but i'll be running n2o soon so i just want to have something to referance wether or not the car runs lean through the rpm range. hard to choke up $240 bucks for a wide band right now with all that i'm in the middle of right now. i'll change it out later on as more mods and parts are upgraded. right now i'd spend that money on a digital 6 plus box so i can get the timming retard for the juce. that way i can run advanced timming strolling around. i allready have a msd digital window switch w/tach. picked it up for $50 bucks.
89 GT
If you want to run nitrous, read your plugs.. do not rely on that narrowband for that. You can get an innovate LC-1 with a gauge for 150-170.
modded 95 gt vert
I never knew how important a wideband was until i started tuning my car. The wideband runs in realtime so if you have a lean spike or if your running lean up top or low you will be able to see it and correct it right away.
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
1991 mustang 5.0
Sooo can anyone answer the second part of my question? Why would my car warm up in traffic and only do it once in a while?
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
because you are moving slow. more air moves around the rad when you are moving. do you have a mechanical fan or electric fan installed? If mechanical, your fan clutch could be shot. If electrical, maybe it is too small. I used to run a 2 row rad out here in az and it would get to the middle of the range in my 88. I have a 3 row installed now (stock style from a 92 vert) and it barely touches the second dash mark from the bottom. I know these things aren't accurate but I thought I'd share my findings.
1991 mustang 5.0
I have a mechanical stock fan with a new single row aluminum rad. Ahh fan clutch... that makes sense. Thanks.
The Big Spoon
never fast enough
that single row cant be helping things either.
1991 mustang 5.0
It stays in the middle 90% of the time. Just once in a while it will climb pretty high.
modded 95 gt vert
there is no fan clutch on an electric fan....
1991 mustang 5.0
The Big Spoon
never fast enough
Threads Similar to: Temp question
| Oil temp gauge question | carl418 | 2005 - 2010 | 8 | August 29th, 2011 09:26 PM |
| question for temp gauge | jasons_98gt | 96-98 | 7 | January 20th, 2010 11:19 PM |
| Thermostat/Temp question | 97CobraNow | 4V / SVT | 6 | June 24th, 2009 08:44 PM |
| Coolant TEmp Sensor question | nHuman | 96-98 | 2 | August 19th, 2008 04:08 PM |
| Just Got My 95 GT...temp. question | Traidmarx | 5.0 Mustangs | 17 | August 5th, 2008 04:50 PM |
