Tire size 89 LX......
Old May 21st, 2007, 04:01 PM   #1
hot89's Avatar
1989 mustang lx
? not sure
hot89 is on a distinguished road
Send a message via MSN to hot89
I'm going to put (waiting for my order to come in) a set of Weld drag lite 15 x 8 with 275/50/15 on the back, does anyone know if I am going to have to do any mod's to the body?
Old May 21st, 2007, 04:04 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
they should fit no problem,but the tires are a little wide, maybe some wheel spcers should fix that
Old May 21st, 2007, 04:05 PM   #3
hot89's Avatar
1989 mustang lx
? not sure
do you think 1/4 would be ok? or too much?
Old May 21st, 2007, 04:21 PM   #4
TurboLX's Avatar
should be fine
Old May 21st, 2007, 04:33 PM   #5
1993 notch
joe 5.0 is on a distinguished road
i hav 265 tires and mine rub the fender once and a while they came with the car not sure on the back space but i have 15x8 wheels
Old May 21st, 2007, 04:48 PM   #6
hot89's Avatar
1989 mustang lx
? not sure
So Joe 5.0 do you know if you have any added spacers then?
Old May 21st, 2007, 04:54 PM   #7
hot89's Avatar
1989 mustang lx
? not sure
so as i can tell 275 tire's i need to add 1/4 spacers? and 265 should be ok to just bolt on with a 15x8 rim
Old May 21st, 2007, 05:23 PM   #8
TurboLX's Avatar
yea 265 would be more ideal
Old May 21st, 2007, 06:42 PM   #9
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
those 275s will fit no problem as long as you have 5.5 backspace.
There's a reason Ford codenamed them the Terminator
Old May 21st, 2007, 09:24 PM   #10
hot89's Avatar
1989 mustang lx
? not sure
have the rest of you had the 275/50/15 with no back spacer on a 15x8 rim as well? joe is saying the 265 rub.i am thinking the rim that is 15x8 would be 5.5 back spacing standard when you buy it from the store . i was going to get the 265/50/15 but if i could go with the 275 i would be happy, i'll just need to buy 1/4 spacers, but would just like to be able to bolt on to the car.
Old May 21st, 2007, 09:55 PM   #11
89LX347's Avatar
89LX347 will become famous soon enough
i have had both the 275's and the 265's on my 89 lx..i didnt have to do anything to make them fit and they didnt rub at all but if there were to rub it would be on the exhaust b/c i have tail pipes..you may not
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old May 22nd, 2007, 08:45 PM   #12
1993 notch
I have no spacers on it
they rub on the outer part of the tire not the inner
but like i said im not sure the back spacing is correct
Old May 22nd, 2007, 09:47 PM   #13
hot89's Avatar
1989 mustang lx
? not sure
ok i did not say but i did cut the tail pipe off thanks for the help i will go with the 275
Old May 22nd, 2007, 09:49 PM   #14
hot89's Avatar
1989 mustang lx
? not sure
and i got to say this is the best web site i have sen yet
Old May 23rd, 2007, 09:45 PM   #15
TurboLX's Avatar
well we dont call it modded mustangs for noting, and we have way less post whores then MF
Threads Similar to: Tire size 89 LX......
tire size wadepetersen V6 Mustangs 4 August 28th, 2007 01:46 PM
tire size dark-samurai2 V6 Mustangs 24 August 17th, 2007 12:02 AM
tire size hopper 5.0 Mustangs 4 June 20th, 2007 11:51 AM
Tire size???? noob 99-04 5 May 27th, 2007 06:44 PM
What tire size? product1620 96-98 6 May 1st, 2007 09:11 PM
