How do u remove stk radio in 89 gt
Old September 6th, 2011, 05:25 PM   #1
1989 ford mustang gt
Reddevil89 is on a distinguished road
how the heck do i get the stock radio out i tried the hanger thing. i got it to work in my parents 95 bird but this thing will not come out. i stuck them in so far and pulled nothing. pushed them in farther and nothing. dang thing wont release maybe the actual tool is needed. PLEASE HELP thanks Reddevil89 (Allen)
Old September 6th, 2011, 05:32 PM   #2
1990 Mustang GT
Stevo077 is on a distinguished road
I used the tool, came out easy. Picked one up from walmart for $10-15
1990 Mustang GT
Old September 6th, 2011, 05:46 PM   #3
Shelby's Minion
RZNCAIN's Avatar
2007 Mustang Shelby GT
(Mach1) Sept. '10 ROTM
RZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud of
metal coat hanger work too.
Sponsored by Specialty Coatings
Car Salesman Club- Founder
2007 Shelby GT- Hardparked
2003 Mach 1- Hardparked
1988 LX 5.0- Umm...Driver?
Old September 6th, 2011, 05:50 PM   #4
fogged306's Avatar
89 GT
If you push them in too far, you can push the tabs on the lock mechanism out to a point where the correct tool won't even release it. I've had a ford or two where someone tried the coat hangar method and went too far, and I had to take the radio out in pieces.
Old September 6th, 2011, 05:55 PM   #5
tried the hanger thing maybe ill try the tools and if those dont work can i take out console to get to the back of the radio. damn it i didnt want to hear bout braking the radio cause its still good. like to keep stock parts. guess never know when ull need them again.
Old September 6th, 2011, 06:06 PM   #6
fogged306's Avatar
89 GT
I don't know how tight space is back there on a stock fox, but if you can get your head up by the gas pedal and look toward the back of the radio, you may be able to see what you're working with. If you can get to them, all they do is push in toward the radio. Maybe you can get a long flathead in through the back and release the clips.
If you do buy the keys, just slide them in gently until you feel them click. Then angle the keys away from the radio and pull out on it.
Threads Similar to: How do u remove stk radio in 89 gt
How To Remove Codeman V6 Mustangs 2 August 10th, 2010 08:10 PM
How do I remove this? crappy_head 99-04 6 March 21st, 2009 02:40 PM
How do you remove your DRL? energiesource 99-04 15 May 19th, 2008 11:29 PM
remove Radio Ware Audio/Video 1 February 18th, 2007 07:04 PM
