What Could It Be?
My 93 5.0 has developed a vibration problem. The vibration is worst in 2nd gear between 2000rpms and 3000rpm and third gear between 1500rpms and 2000rpm while accelerating but present in all gears to some degree. It really can be felt through the steering wheel. While cruising at a steady speed it almost goes away. The engine shakes a little while at idle and reving in neutral does not produce any vibration. I inspected the car and the driver side motor mount is cracked and appears to be missing a chunk of rubber. Is this the obvious culprit or should I look further?
2006 GT
11.99@114
Since you feel it in the steering wheel its most likely a tire out of balance or bad tire. How is your alignment? Wouldn’t hurt to replace those motor mounts while the car is up on the lift.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
Thanks for the reply Gt. I switched the tires front to back and still got the same vibration. I was thinking that because of the dirvers side mounts close proximity to the steering wheel linkage and shaft it mite transmit vibration. What should I look at on the suspension.
2006 GT
11.99@114
Vibration at specific RPM usually means it is related to parts that rotate i.e. tires, wheels, drive shaft, u-joints, etc.
Its present all the time just worse(really noticeable) at those rpms. I will have to look at the drive shaft and u joints. The motor mounts have to go no matter what. Thanks again for the advice!
1991 gt vert
check your harmonic balancer. if their is rubber sqeezing out around it between the inner and outer rings than thats prolly the issue. very common with the 5.0's. i ve had a simmilar vibration since i got my fox last october.i allready replaced u-joints,drive shaft,motor mounts, and tranny mount. all of those parts helped alot, but i still have a small vibration! i'm building another motor though so im just going to let it ride for now. i'm going to buy a new summit balancer for it and put the stock balancer from the one im building on my old block
92 LX 2.3N/A
I had something similar. turned out to be the fuel filter. also had trouble starting, and wouldn't go past 35-40mph
Thanks for the replys. Funny, my fuel pump just went out about 3 weeks ago. I didnt change the filter then. mite give it a try. Mine will go as fast as needed just rattles a lot at certain rpms. I am gonna get back under the car tomorrow.
1989 Mustang GT 5.0
Tires could be screwed up, wheels could be out of balance, new motor mounts would help. Driveshaft could be off balance...
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1991 Ford Mustang GT
Id say
tires wheels balancer drive shaft motor mounts
How should i go about inspecting the drive shaft?
Couldnt get under the car today I did run the rpms up with the car in place to see if vibration could be felt. Well no vibration. So guess that rules out the accessories and the crank.
