i have hit a set back on 92.50
as some of u know me and my gf just bought our forst 92 gt with 81,000 miles on it. we had planned to take motor out this winter do a slight rebuild and new paint all over. well i was able to get under it yesterday and had a total shock. behind the bumper cover on the rear on driverside is all rusted out it has a small hole in corner of floor pan and a ton of surface rust. i belive the rear suspension and front is shot. my our plan was to take motor out like i said take everything out of engine bay and sand down and fab weld some spot. dron front and real susp and replace all rebuild the rear end tranny and motor. we r doing all the work ourself along with friend from foxbody club. we kinda set a budget of 5,500 for parts and what not but after seeing all the bad rust not sure if its a good idea to contiue with project. if anyone has suguestions please feel free to comment. ill get some photos of the bad spots soon.
93 Mustang LX 5.0 5spd
N/A
I'd look for another drop top to build...I have only had to deal with rust a little here and there and its a real pain in the a$$ to deal with...unless you have access to a welder and sheet metal and have a lot of times on your hands to work on it....good luck on which ever you decide...
1993 mustang gt
stock
Rust can be a bitch but dont let it stop you i had a 66 impalathat sat out in the element for 10 years before i got to it the whole bottom side of the car was ate away every quarter panel the rear quarters were almost non existant a lot of fiberglass and body filler it was restored to its original glory until some old ass bitch totaled it doin 55 in a 15 while my car was trying to turn in somebodys driveway smacked it in the rear twisted my tailpipes frame and my heart
1993 mustang gt
stock
1993 mustang gt
stock
That woman shouldve been arrested for being blind as a bat how could u miss that thing it was broad daylight all that work for nothing on the upside i only payed 3000 and i got 5000 from the insurance plus my girl got a lawyer n is about to recieve 7 or 8 thousand for fn up her back ( these old cars only had lap belts so she got jerked quite a bit)
#6 | |
1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
Op, Post pictures of the stang so everyone can make suggestions
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
I'm having trouble uploading pics. Im thinking I'm going to replace drive quarter panel and fender aprons. One the body work is done we r going to sandblast the under neither then spray it with some sort of rust stopper then seal it all off.
1991 Ford Mustang GT
I got the same problem myself. I bought mine and the car looked beautiful. From the outside you would never suspect any rust. But underneath is a ton of rust.
All four corners of the floor pans are rusted out including a little rust up the driver side kick panel. Honestly I am not worried about the floor pans since I can replace them. I have a welder and other tools to do the job. However I also found a bunch of rust in the rear. The actual body is ok in the rear except the lower quarter panels behind the bumpers are rusted completely through. The rear frame and bumper is rusted badly. The lower quarter panels, bumper, etc. can all be fixed without much trouble for me. But the frame being rusted scares the crap out of me. It has a big hole in it and the frame isn't something I want rusted out. I was considering trying to grind it all off and see if I can get it down to bare metal, then weld some new steel on the outside edges of the rear frame to strengthen it up. I am also thinking this may turn out more expensive than just getting a roller. This car is a hatchback and I kind of want a coupe so I may buy a coupe roller and move everything over. |
Threads Similar to: i have hit a set back on 92.50
| Notch back or Hatch back | ponyonsteroids | 5.0 Mustangs | 59 | January 19th, 2012 05:49 PM |
| Axle-Back on a Cat-Back | clodingos97 | 2011+ | 16 | August 30th, 2011 09:50 PM |
| Bassani Axel back VS Magnaflow Axel Back.. What to get! | myroush6 | 2005 - 2010 | 27 | June 7th, 2010 03:51 PM |
| Magnaflow overstock blowout sale on V6 axle back and V8 cat-back | PFYC | PartsForYourCar.com | 0 | July 10th, 2009 09:33 AM |
| Questions about Axle back & Cat back exhaust | Scion | V6 Mustangs | 2 | October 9th, 2006 07:44 AM |
