1993 lx 351 coupe
![]() iTrader: 1 reviews
Need a cam....help ASAP
Alright guys so I'm getting the parts together to build up my new toy..a bone stock 89' GT automatic.
My parts so far are an Edelbrock Performer 5.0 intake thats ported and polished, a set of GT40P heads that just got rebuilt with new valves, retainers, comp cam bee hive springs good up to .600 lift and converted to stud rockers, scorpion 1.6 roller rockers, BBK shorty headers, off road x pipe, 3200 stall convertor, 3.73 gears...and some other stuff.... Now to my question what size cam can i run with the stock pistons? I'm trying to stay away form the ford letter cams heard some bad things about them. Is anyone running an Anderson cam N 41, N 71? or the Trick flow Stage 1 or 2? I looking for the biggest lopping cam possible! plain and simple. The car is going to be a weekend driver around town will never go on a track. I want to pull up at the red light and have the guy next to me ask what the hell is done to that thing , my 93 351 had a .520 cam and i want to go bigger with this build. So what is the biggest I can go? Keep in mind my heads are built to hold it, just need to know what cam to run. Thanks guys
![]() Killer Performance |
1993 lx 351 coupe
Bump!!!!!
1989 Black LX---Turbo
No matter what cam you go with, you will have to check piston to valve clearance, just to be safe. No sense putting all that money into you motor, just to have a failure. I think the Anderson N41 would be an excellent choice.
I've got a stock 89 HO short block in my 82 Capri with a Comp XE266HR cam (216/224 @ .050 w/ 544/555 lift), box stock Twisted Wedge 170 heads and 1.6 roller rockers. When I checked my PTV clearance I had over .100 on both intake & exhaust, but every motor is different. I've got to say the XE266 is an excellent cam, way, way more power, drivabuility, rumpy idle than the old E303 I replaced.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1991 mustang 5.0
I've got an f cam and I like it. It makes pretty good power and has a sweet idle
1969 Mustang Mach 1
6.824@101.61
Good choice on skipping the letter cam. Of you go with Anderson, make sure you ask them if your springs will work with their cam. No spring is good to xxx amount of lift. Springs just don't work that way, and typically, you should buy the springs after the cam, to make sure you get the proper ones for the cam.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
afm n51
07 GT/CS
12.12 @117.53 mph
N41 is a great cam thats what we have in my sons 91 GT. Nice lope at idle.
See Garage for Mods ![]() 225-753-3966
1992 Mustang GT
dont know yet
The trick flow stage 1 cam sounds nice this is the cam I am running in my car and I really like it.
Good luck choosing a cam. Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
I got a trick flow stage one cam as well. it is a great cam as well
93 LX Hatchback H/C/I Full Suspension 06 Ford Explorer Limited |
#10 | |
1993 lx 351 coupe
1992 Mustang GT
dont know yet
40 series delta flow (changing to original 40 series) bbk equal length shorty headers, bbk off road x pipe.
1992 Mustang LX
13.0 @ 105
Get the N41 cam from Anderson. Great grind for those heads. I've seen STOCK gt40p heads with that cam and an explorer intake that is ported go 11.9.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
Threads Similar to: Need a cam....help ASAP
| CAI Help asap | CheyenneMustang | V6 Mustangs | 5 | May 5th, 2011 06:03 PM |
| need a new fox asap | oscrfsh | 5.0 Mustangs | 14 | November 29th, 2009 11:55 AM |
| Need help asap. | Codeman | V6 Mustangs | 11 | July 14th, 2009 12:08 PM |
| Need help asap. | Dansby | The Clubhouse | 50 | June 23rd, 2009 07:17 PM |
| need help asap | 91cobra5.0 | 5.0 Mustangs | 8 | April 16th, 2008 07:20 PM |
