1999 mustang gt
will a 93 vic engine fit????
Ok so my stang basiclly need a new motor and I have came across a 1993 crown vic 5.0 with 83000 miles on it for a cheap price. and was wantin to know if it would be compatible in my mustang?
1990 mustang gt, gt40heads f303 cam , and bolt ons |
I could be wrong? But Ford didnt make a 1993 Crown Vic with a 5.0! It come with a 4.6 V8 and auto trans. Better make sure you have a OHV 5.0!
1990 LX 5.0 2000 Expedition 2002 Honda Accord One tea cup Chihuahua guard dog!!!!!!! |
1999 mustang gt
oh well maby my year info is of but will a crown vic 5.0 work
89 GT
Yes. Just swap over your intake and sensors and front accessories.
1999 mustang gt
Ok but I heard some thing about the crown vic engines being non h.o. is this true if so will it affect anything. But if it does work wat all is needed to make the switch?
1992 Mustang LX
13.0 @ 105
What makes the h.o an h.o is the cam and firing order. Once you do mods it wont matter a thing.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
89 GT
^ What he said. You'll need to swap in a cam with the 351 firing order (same as the 302 HO). My bad, I forgot to mention that.
1999 mustang gt
Ok well my messed up motor has a f303 cam in it so all I have to do it change the cam over?
But on another note my motor got killed because of no oil pressure, it started making a really weird noise and the mechanic said it was the lifters that they where rattaling and that they had calapsed so do u guys think that my motor is still fixable or should I just go with the new block?
89 GT
Depends on how mechanically inclined you are. If you can, I would pull it apart and inspect your bearings. If you do end up using that vic engine, I would clean up the GT-40's and put them on it. They'll be better than the E7's on the vic engine.
1999 mustang gt
1999 mustang gt
well I really wouldn't know what to check for so u think I'm better of transfering all my mods to the new block by haveing someone else do it?
89 GT
It all depends on the shape of your engine vs. the one from the vic. I can't tell you either way because I have no way of knowing. Depending on how long and why yours starved for oil, it may still be ok or it may be shot. 83k is good mileage, but still doesn't tell you the condition of the engine. Those could be hard neglected miles, they could be babied maintained miles, or they could fall somewhere inbetween. No way of knowing for sure without pulling that one apart too.
1999 mustang gt
well the motor ran like 15 miles like that so i think its gone. so how much do u guys estimate it will cost to have my heads, cam, and other stuff need for the swap put on the new block and have it installed in my car?
thanks for all the help so far
If your bottom end is good and is a roller motor then all you need to do is swap your heads, cam and intake. If your heads are the same as the vic then leave them alone unless you want to pull them. If it was me i would go buy a Explorer 5.0 and simply swap my Mustang stuff onto the Explore motor and drop it in.
1999 mustang gt
Ok so how much should I expect to be charged for the work?
1992 Mustang LX
13.0 @ 105
That's probably a 10 hour job according to a shop. Figure about 70$ an hour. Could be more than 10 hours, I'm just guessing.
Threads Similar to: will a 93 vic engine fit????
| 03 crown victoria engine vs. 2003 mustang gt engine?? Which tko 500? | 98 Stanga Banga | 99-04 | 8 | September 20th, 2010 08:25 PM |
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Washed n cleaned engine today.. pics of engine bay. | MustanG_guy17 | The Clubhouse | 40 | January 4th, 2008 10:14 PM |
