fuel problem
Old September 9th, 2011, 08:10 PM   #1
95project is on a distinguished road
fuel problem
Car was running great, turned it off,tried to restart and it wouldn't. I noticed the fuel pump was running constantly when the key is on. Replaced the fuel pump cause I needed a bigger one anyway, and its doing the same thing. Suggestions??
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old September 10th, 2011, 12:08 AM   #2
50Droptop's Avatar
87 Mustang Lx
13.76@100
50Droptop is on a distinguished road
Fuel pump relay.
Shawn
87 Coupe
The Notch
Old September 10th, 2011, 05:26 AM   #3
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
+1 Relay is sodded or you have some wires shorting out somewhere but more than likely the relay.
Old September 11th, 2011, 03:28 AM   #4
EscortSportage's Avatar
1989 Mustang GT 5.0
Relay under the driver seat
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old September 11th, 2011, 12:05 PM   #5
ryanw's Avatar
1991 Ford Mustang GT
If your car is a 1995 the fuel pump relay is not under the seat, i think its on the passenger side strut tower. 1991 and under the relay is under the drivers seat and 1992 and up, its under the hood
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old September 13th, 2011, 11:09 AM   #6
yes, its a 95...
Apparently, there is not a stand alone relay for the fuel pump...it is included with a few others inside a box called the Constant Control Relay Module....which costs about 175 wholesale and is dealer only part....anyone confirm this??
Old September 27th, 2011, 02:00 AM   #7
1994 Mustang GT
94Stang5.0L is on a distinguished road
Originally Posted by 95project View Post
yes, its a 95...
I recently replaced mine on my 94 which is located behind the radiator in front of the coolant reservoir. I had to get mine from Ford itself and cost me $230. if you check anywhere like autozone, pep boys, o Reilleys, or even napa. they will say they dont have it because they dont know it as an constant control relay module. they know it as the powertrain control module. wish i woulda found that out before i bought it from ford. But atleast i know it was the right one
Old September 27th, 2011, 08:55 AM   #8
fogged306's Avatar
89 GT
How was it tuned, did pops burn a chip? May be a longshot, but if I load a blank tune into my car the fuel pump will run constantly with ignition and do nothing else. It could be that the chip failed or isn't making contact all the way. Like I said, longshot though probably. I would find the pin that is for the fuel pump output and double check and make sure it's not sending a constant ground signal while the ignition is on.
Old September 27th, 2011, 05:21 PM   #9
It got a Moates QH..Pop's wrote the tune for me..i will try this also. Thanks!
Old September 27th, 2011, 05:28 PM   #10
fogged306's Avatar
89 GT
Did you happen to be playing with the QH before this happened? If you don't have the hardware tab set-up correctly in BE and you try to make any changes to the tune it will load a blank. It'll look like it wrote to the QH and everything too so you wouldn't know anything was wrong until you went to start it.
Old September 28th, 2011, 10:48 AM   #11
No, i had not messed with it at all. I started the car, drove to best buy to meet a guy and pick up an S281 spoiler, got back in it to leave and it would not start....just for shits and giggles, i will reload the calibration and try it before i tear into the CCRM.
Threads Similar to: fuel problem
Fuel problem? 2VSouth 99-04 15 October 6th, 2011 07:16 PM
fuel problem S my 5.0 5.0 Mustangs 5 July 6th, 2011 10:33 PM
need help please!! fuel problem joedaddy4 94-95 9 October 10th, 2009 11:43 AM
need help please, fuel problem!!! joedaddy4 5.0 Mustangs 7 May 11th, 2009 11:41 PM
92 s10... possible fuel problem? ItaliStang All Other Vehicles 4 October 6th, 2008 12:25 AM
