tfs hci now no power
i just finished my build and decided to take her around the block and was very disapointed there was no power at all way less then in stock form my build consisted of 170cc track heat heads stage 2 cam track heat intake msd 6al 75mm tb and pro m mass air 24lb injectors and stock bottom end and my timing is 13* advanced any idea where to start?
Are you sure your cam timing is correct, this is the only thing I can think of at the moment.
315's Crew Black and White Crew Crew Member #2
u mean timing to the crank? or distributor position?
1990 Mustang GT
ya, try setting it just by ear, see where it sounds the best, adjust it with it running, tap on the gas a bit and see where you get max power
![]() 1990 Mustang GT |
yea im gona try to advance it further hopefully that helps
89 GT
He said cam timing, not ignition timing. Did you degree the cam when you installed it?
yea i checked to make sure it was perfect 5 times..... the car idles smooth and drives well just when i try to get on it theres no tourque just a slow climb to 5k rpm
89 GT
Then start with the basics. Check the plugs and see what they look like. Check your cranking compression. Check your fuel pressure. And make sure the balancer hasn't spun and your timing marks are off. Also are you sure you have the timing set to 13*BTDC. I've seen people set their timing to ATDC and not realize it and the car was a dog. If I was to guess, I would say you have something incorrect with your ignition timing if you degreed the cam.
that may be it ill have to check that because when i set the timing i had cylinder 1 atdc
89 GT
You set the timing with the car running and a timing light. When you stab the distributor, all you're doing is making sure you're on the correct tooth for where you have your number 1 cylinder on the cap. The initial timing adjustment is done after that. Also you have to remove the SPOUT connector before you set the timing.
1992 Mustang GT
dont know yet
Do you have gears in it? What fuel pump size? I did the same swap but haven't done gears in it yet and it's a dog in any gear after second. My base timing is set at 15 with the spout out it made a huge difference and a tune will help alot.
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
#12 | |
1992 Mustang GT
dont know yet
When I did mine I called trick flow they also said that it would need tuned. it is probably running pig rich huh?
1991 Ford Mustang GT
i did the same thing when i first installed my engine. i set it at 10 advanced and i had no power....set it at 10-14 btdc
I just bumped the timing to 18* an wow what a huge difference all is well now
18 advancer or retarded ?
Do you still have the stock balancer ? The reason i ask is that it may have spun, meaning that you dont have the accurate reading of your real timming
18 advance and yea I still have stock balancer when I reinstalled it it didn't look bad though.
Now should next step be a dyno tune? Because guys have been telling me these motors don't benefit much from one is that true?
1992 Mustang GT
dont know yet
IMHO any car can benefit from being tuned but with the changes to your setup you will want to. As it sits right now I guarantee you are running rich and will have very poor fuel economy. Also with the timing advanced that much you might want to consider running higher quality fuel ie 91-93 octane to help prevent the chances of detonation. But the tuner will get you optimal performance. Do you NEED one no but it would benefit you as far as gas mileage and the most power for your setup.
Threads Similar to: tfs hci now no power
| Need more Power!!! Help please | WXI | 99-04 | 29 | May 17th, 2011 02:06 PM |
| Is there a Brak kit to go from non power to power? | steelcityfan29 | Classic Mustangs | 15 | January 6th, 2011 03:57 PM |
| how much power can i expect with these upgrades?or what can i do for mad power? | muscletang420 | 99-04 | 34 | October 30th, 2010 10:54 AM |
| 1998 power window motor has power then installed its dead?? | crabbymaddy | V6 Mustangs | 2 | September 19th, 2010 07:26 PM |
