what to launch at
Old May 22nd, 2007, 12:39 AM   #1
gordon norris is on a distinguished road
what to launch at
hey i have had front wheel drive cars mostly and one the would spin THE tire off threw drive so i was at a light and thought i would see what i could launch at so i started at 2000rpm and spun the tires up all the way threw 1 and half way threw 2 so is this how these car are stock or is my suspension just that bad i have Dunlap's on the back they should be OK tires right i was thinking of going the the track but if i cant even launch at 2000rpms my times is really going to suck
Old May 22nd, 2007, 12:47 AM   #2
1991 LX, 2003 SNK, 2007 S
11.3
cams-shelbycobra07 is on a distinguished road
Send a message via AIM to cams-shelbycobra07
Drag radials my friend
Old May 22nd, 2007, 01:12 AM   #3
fogged306's Avatar
89 GT
what's your setup? are you one wheel peeling? A rearend rebuild might be in order along with some new suspension parts.
Old May 22nd, 2007, 01:30 AM   #4
Stangzilla's Avatar
Stangzilla is on a distinguished road
Well that depends on how much power you have. Generally street tires will not give you your best times at the track but remember the first 60' of a dragstrip has at least a 1\4 inch of rubber on the track.. If you have ever walked on it you see it feels like glue if the track is prepped right of course.. Even with street tires on the dragstrip if you launch at 2k you will prob be ok just dont mash the pedal the the floor. Feel the car feel the track and roll into it until you get to full throttle.. After second gear if your car is not heavily modded you should be able to mash the pedal after the 2nd to 3rd shift.. Of course drag radials will help you.. Unless you have 17inch rims or better then drag radial performance is not much better than regular street tires and I would not waste your money.. Drag radials work best with a 15' inch rim because there is plenty of sidewall to flex and absorb some of the shock of the launch where 17inch and larger tires have viturally no sidewall at all and what it does have is way to stiff to absorb. They just spin also... Even 16inch wheels would be somewhat ok for drag radials but for sure a big fat no to 17inch and up... Waste of $$
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old May 23rd, 2007, 12:39 AM   #5
well my car is all stock only thing done is headmen headers and flowmaster mufflers so that's what i was saying even if my tires really suck a stock mustang shouldn't spin them up that much unless the rear suspension sucks right
Old May 23rd, 2007, 12:41 AM   #6
OH and the rearend is fine both tires spin it leaves to tire marks and kicks the car sideways
Old May 23rd, 2007, 10:18 AM   #7
Stangzilla's Avatar
Yeah a stock Mustang will spin that much.. Its a rear wheel drive V8 thats pretty light...
Old May 23rd, 2007, 11:48 AM   #8
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
I have a hotchkis rear suspension and 3.73 gears and mine spins like crazy until the seacond to third gear shift then I can hit it to the floor
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old May 23rd, 2007, 01:30 PM   #9
95wip is on a distinguished road
Send a message via AIM to 95wip
drag radials will still be a huge difference over street tires and help you alot...although they would work better on 15s they will still do great things on 17s but they have to be wide enough and correct preasure in them and they have to be hot or you are wasting your time
95' GT is being reconstructed!
Threads Similar to: what to launch at
launch MustangMatt96GT 96-98 12 May 23rd, 2007 08:26 PM
What rpm to launch from mikedoogen 2005 - 2010 1 May 12th, 2007 01:28 AM
Help! Can't Launch My Car JBIGBOOTSY 5.0 Mustangs 3 October 8th, 2006 05:20 AM
What RPM Should I Launch At? 00SoSlow Drag 24 September 30th, 2006 10:53 PM
can't launch JBIGBOOTSY Drag 2 August 7th, 2006 10:56 AM
