cooling issue
Old September 11th, 2011, 01:32 AM   #1
shamrock81887's Avatar
1993 mustang gt
stock
shamrock81887 is on a distinguished road
cooling issue
My 93 gt temp gauge has been actin abnormal when i drive it to work the past couple days ive noticed the gauge fluctuating between half and 3/4 its not the radiator i just replaced it its not dropping fluids im thinkin its my thermostat but im not positive cuz if it were it would not cycle at all and id be going in the red which im not im at a loss and its really bugging me
Old September 11th, 2011, 01:33 AM   #2
1993 mustang gt
stock
And im not givin it hell either im babying it cuz its my freakin baby
Old September 11th, 2011, 01:34 AM   #3
1993 mustang gt
stock
Its a manual if that makes a diff in your answers
Old September 11th, 2011, 02:24 AM   #4
1993 mustang gt
stock
Okay i dont need a diagnosis its fairly impossible to do over the internet in this situation i just need to know if this is normal or not shouldnt it read half at all times unless im givin her hell ( which is rare) i live in ky and its been fairly cool weather lately
Old September 11th, 2011, 02:29 AM   #5
1993 mustang gt
stock
When i drive it i shift at 2500 through all gears maybe 3000 outta first if im turning out in front of close vehicle maybe im not babying it enough? Or is this fine
Old September 11th, 2011, 02:40 AM   #6
1993 mustang gt
stock
I drove to work keeping a eye on it n it read a little over half the whole drive but when i got there n parked it i noticed it started going up all the way to 3/4 then it went down to normal after five minutes of waiting maybe im just freakin out over nuthn uggggg sorry if u guys have seen this a billion times
Old September 11th, 2011, 03:06 AM   #7
EscortSportage's Avatar
1989 Mustang GT 5.0
Make sure u havethe plastic air dam under the radiator mount!!! Without that ur hit, and id check the thermo try replacing it with a 180degree and see what happens
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old September 11th, 2011, 03:22 AM   #8
1993 mustang gt
stock
What is this plastic air dam u speak of sir i just pulld the old leaky rad and dropped a new one in
Old September 11th, 2011, 03:28 AM   #9
1993 mustang gt
stock
Nvm i looked it up i got it
Old September 11th, 2011, 03:30 AM   #10
1989 Mustang GT 5.0
Yes that air dam forces air up into the radiator without it ur not going to get much air in the radiator
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old September 11th, 2011, 03:34 AM   #11
1993 mustang gt
stock
So youd say my issue sounds abnormal yes?
Old September 11th, 2011, 03:37 AM   #12
1989 Mustang GT 5.0
Stock guages stock man get a nice autometer or aem temp guage with a new sending unit
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old September 11th, 2011, 03:42 AM   #13
1989 Mustang GT 5.0
Deff meant stock guages suck
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old September 11th, 2011, 05:22 AM   #14
1993 mustang gt
stock
Yea im startin to see that the other night i got it up to 100 mph n ive had this issue ever since i think i fudged somethin up maybe i blw a head gasket or somethin cuz it shouldnt be runnin hot
Old September 11th, 2011, 05:31 AM   #15
1993 mustang gt
stock
The car only has 85000 miles on it so i figured what the hell lets see wat this puppyz got i ran up the speedo to a bill and the temp gauge read 3/4 it was the first time i saw it go past half but it obviously wasnt the last ive only got five hundred left for emergency car funds til the first of the year then i get another five grand to put in her for a paint job wheels n tires so im sweatin the small stuff cuz if somethin major happens between now n the first im screwed i work at mcdonalds n barely make enough to support my mortgage n utilities
Old September 11th, 2011, 12:07 PM   #16
ryanw's Avatar
1991 Ford Mustang GT
Did you try replacing the sencor in the intake that tells the gauge what your temp is ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old September 11th, 2011, 02:37 PM   #17
1993 mustang gt
stock
maybe the temp gauge is just crappin out idk if i blew a gasket or something wouldnt my engine cpu read it and turn a engine light on or something as of now i have no lights on it runs and sounds good.
Old September 11th, 2011, 02:55 PM   #18
1993 mustang gt
stock
Ok im ordering a a pillar pod and water oil n volt gauge i doubt it will fix anything but i guess it will give me piece of mind how hard are they to install wiring wise
Old September 11th, 2011, 04:51 PM   #19
1990 5.0 LX SSP
Colt.45 is an unknown quantity at this point
Are you running a mechanical or elect.cooling fan? If it's mechanical, your fan clutch could be getting weak. If it's elect. ,the fan may not be coming on when it should. I think you'll like the gauge pod with good gauges. Good luck.
Old September 11th, 2011, 06:04 PM   #20
1993 mustang gt
stock
I think its mechanical it runs off the pulley so i guess mechanical
Threads Similar to: cooling issue
Cooling Issue Help 01 blue bullitt 99-04 13 October 10th, 2009 12:14 AM
Cooling System Issue prosbloom225 V6 Mustangs 8 April 14th, 2009 07:51 PM
Cooling Issue(s)... Lefty 96-98 7 December 1st, 2008 11:50 PM
Cooling Issue(s)... Lefty 99-04 11 December 1st, 2008 12:41 PM
347 Cooling Issue bgddy50 5.0 Mustangs 35 December 27th, 2007 10:34 AM
