whats the proper way to port a manifold
Old September 11th, 2011, 04:50 PM   #1
89stanger1989 is on a distinguished road
i just got a trickflow manifold that came with a 70mm throttle body. i want to make the openings on both a 75mm. i seen people doing it with a dremel and some doing it with a milling machine....whats the proper way? i also have a 65mm throttle body but can that be ported to a 75 or will the walls be to thin?
Old September 11th, 2011, 07:35 PM   #2
1992 Mustang GT
dont know yet
96paxtonstang is on a distinguished road
I'm pretty sure that the trick flow intakes are already 75mm
Sent from my Autoguide iPhone app
______________
Mods:
Paxton Novi 2000 @10psi
3.73 gears
255lph fuel pump
Lucas 42# injectors
Trick Flow 75mm upper intake
Trick Flow 75mm throttle body
Diablo "MAFia"
Dyno tuned by Force Fed performance Sacramento Ca
Old September 12th, 2011, 06:33 PM   #3
you sure? i know the throttle body that came with it is 70mm....either way how do you port the throttle body?
Old September 13th, 2011, 12:27 AM   #4
1992 Mustang GT
dont know yet
Porting that would be more trouble than it's worth. You would need another throttle plate, need to make sure the port is even all the way around. You would be better off buying a 75mm throttle body.
______________
Mods:
3.73 gears
255lph fuel pump
Lucas 42# injectors
Diablo "MAFia"
Old September 13th, 2011, 06:00 PM   #5
if you do the job right you shouldn't have to worry about it being even and i would think a throttle plate is no where near a new throttle body...i still want to port it...if i screw up then i'll get a 75mm
Old September 19th, 2011, 02:52 PM   #6
tmoss's Avatar
tmoss is on a distinguished road
you will screw it up - just get another TB. I've been porting for over 40 years and unless you can machine the bore for the plate, it will be FUBAR.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old September 19th, 2011, 08:37 PM   #7
91cobra5.0's Avatar
98 Cobra
listen when tmoss speaks on porting, but i would look into if that manifold already comes a 75mm, it just might
Threads Similar to: whats the proper way to port a manifold
Port and polish 01 bullitt intake manifold? BBarajas 99-04 2 August 9th, 2011 02:59 AM
port and polish pp intake manifold 2002mieralgray4.6 99-04 2 July 14th, 2011 08:17 PM
Whats best intake manifold? mine cracked JACK MEHOFF 96-98 10 July 13th, 2011 01:07 PM
port matching pi manifold slow98gt 96-98 3 May 11th, 2007 08:27 PM
port and polish intake manifold and throttle body.... camer V6 Mustangs 2 May 9th, 2007 11:08 PM
