1990 Mustang GT
Spout connector
I know the basics about it. Lets your computer mess with the timing and what not, but it seems like my car runs better ( or at least idles better) with it out. My timings around 26* and ive ran it there for a few months without it in. Its wet and rainy, so i cant really go see how it performs at WOT with it in, but anyone have any experience with it?
![]() 1990 Mustang GT |
2000 gt
pull spout, set timing to 14*, then reconnect and see what you think. run 91 octane though.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
1991 Ford Mustang GT
your balancer may have spun, so maybe your timming is way off
Its something to do with allowing the ECU to adjust your timing automatically once it is in... it seems more like a safety feature than anything so you wont mess up the motor...
plus its like 4 dollars... just do it like mustanginky says and you'll have the right timing curve between 10-15deg |
I still haven't advanced my timing. I didn't want to use the premium fuel right now since it's about 10 cents more a gallon. I know I'm cheap
#6 | |
89 GT
With the timing locked you may notice it starts harder. This is because the computer normally retards the timing during crank and can't with the SPOUT out. Other than that, you won't have any issues with it causing damage. I've run my timing locked before and it was a little more responsive on my engine. Mileage suffered a little though during cruise. |
Threads Similar to: Spout connector
| Spout connector question | 428CJ | 5.0 Mustangs | 10 | April 8th, 2011 11:38 PM |
| Question regarding setting timing and spout connector | Phinney | 2.3 Mustangs | 6 | March 29th, 2011 02:53 AM |
| Spout Connector?? | Dap1991 | 5.0 Mustangs | 10 | May 23rd, 2010 08:15 PM |
| Spout connector | JBIGBOOTSY | 5.0 Mustangs | 8 | April 12th, 2009 09:19 AM |
| Spout | flamed 98 gt | 5.0 Mustangs | 15 | January 13th, 2008 03:25 PM |
