1989 notch
heads and intake
have 89 notch with gt40x heads and gt40 intake want to upgrage to a better combo?? looking at afr 185 any info is appreciated. also has s-trim
1990 5.0 LX SSP
I have a TFS Track Heat hci on a DSS 306 pro bullet short block. It makes 290 at the wheels corrected, 310 uncorrected. I'm sure there's people out there with custom set ups that may be better.
1992 Mustang GT
dont know yet
Plus the TFS 170s out flow the AFR 185s
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
1989 Black LX---Turbo
No they don't!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1992 Mustang GT
dont know yet
My bad TFS 170s out flow AFR 180s not the 185s
if your wanting to put down serious power later on the AFR's are the way to go.
1992 Mustang LX
13.0 @ 105
Get trick flow twisted wedge FAC 190cc heads...great bang for your buck and they fit very well on a stock piston 302.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1969 Mustang Mach 1
6.824@101.61
Unless you have a dart block, I'd leave what you have.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1989 notch
what intake ?? tfs , holley??
AFR 165 would be the next step down from the 185 in Ford heads. In 2003 Westech Dyno did an independent flow test of aftermarket Ford heads. The AFR 165 flowed 240I/200E @.550 and the TW 170 flowed 248I/191E @ 550, so those 2 heads flow very close to the same!
1989 notch
guy with 8 sec car told me to get afr 205 because of super charger, does that sound right ?? any fast guys with info on that
Like 69fastback said, unless you have an aftermarket block there is no need to go with a super high flowing head, because your block will be the week link!
1969 Mustang Mach 1
6.824@101.61
Why an AFR 205? And why is that supposed to be best for a supercharger?
1991 Ford Mustang GT
AFR 165 and trick flow 170 flow about the same. but trick flow 185 out flows AFR 185,from what im told
Im running AFR 185, and i like them
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; September 19th, 2011 at 11:01 PM. |
1969 Mustang Mach 1
6.824@101.61
That can't be right. I don't get into flow numbers, but a TW 170 is way more head than an AFR 165.
I have heard that the Tf 170 does flow better then the afr 165, but not by to much
1989 notch
1969 Mustang Mach 1
6.824@101.61
1989 notch
@69 either or would be good ?? and where can i get a good deal on these seams like everybody mail order these days
check them out used on The Corral
Threads Similar to: heads and intake
| Heads,Cam,Intake. | 91Mustang GT | 5.0 Mustangs | 8 | August 4th, 2010 07:21 PM |
| C&L intake and heads | silverstang | 2005 - 2010 | 15 | February 9th, 2009 08:15 PM |
| GT-40 Intake and Heads | 89StAngerLX | 5.0 Mustangs | 9 | November 13th, 2007 01:34 PM |
| Heads and intake | Tony_90fox | 5.0 Mustangs | 3 | July 14th, 2006 03:22 AM |
