Need intake opinions!!
Old September 17th, 2011, 10:51 PM   #1
bl_rdrgz's Avatar
1991 Mustang GT 5.0
bl_rdrgz is on a distinguished road
Post
Ok so I have a completely stock 5.0 have a catless bbk h-pipe that's about it. Just wanted to know which intake you guys would suggest. Eventually I will do more upgrades. So I want something that will be able to handle at least other aftermarket upgrades. I am building a street racer not a drag car. Any opinions would be greatly appreciated! Thanks!
Old September 18th, 2011, 04:00 AM   #2
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
stock intake is good for low end to midrange power so dont discard it yet, you'd be suprised what it can do...
if your looking for more HP the trickflow street is a pretty good way to go...
but if your building a street racer first things you need to do:
Subframe connectors, lower K-member bar, Strut brace front and rear.
Brake kit upgrade (no point of more power if you cant stop)
suspension upgrades, lower the centre of grav get better handling, castor camber plates, stiffer sway bars...
wheels 17x8 or 18x8 up front and 17x10.5 or 18x10 on the rear... that way you can fir a nice wide tyre and get good traction...
replace the stock seats 1 weighs about 3 times more than an aftermarket seat,
Old September 18th, 2011, 08:41 AM   #3
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
You have to decide what you're planning and on what budget. I would say get a trick flow r series intake and put it on later. On a stock motor it would be stupid, lol.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old September 19th, 2011, 02:49 PM   #4
tmoss's Avatar
tmoss is on a distinguished road
internal EGR Explorer intake from a JY - run it stock for now and port the lower later if using heads that flow up to ~260cfm. Any head above 260 cfm prob needs a bigger intake.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old September 19th, 2011, 11:14 PM   #5
ryanw's Avatar
1991 Ford Mustang GT
If your engine is all stock i wouldnt bother with an intake swap at this time. swap the intake when you swap out cylinder heads. other wise id start with sub frame conectors, rear end gears and a good set of tires. maybe replace all the worn out bushing and Suspension
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old September 20th, 2011, 06:50 AM   #6
2006 GT
11.99@114
1LOUDGT is on a distinguished road
I agree. First mod should be full length weld in sub frame connectors. People who haven’t done it cant appreciate the drive quality.
2006 GT (Fastest)
2004 COBRA (Faster)
1990 LX 5.0 (Fast)
Old September 20th, 2011, 09:16 AM   #7
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
Gears!!!!.If you've got a 5-speed get 3.73's,if you have an AOD get 4.10's.Best bang for the buck.My first mod was to get 4.10's
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Threads Similar to: Need intake opinions!!
Stock intake manifold cracked =( opinions anyone? OhOneVert 99-04 22 September 14th, 2010 07:49 AM
Need some opinions on....sniper tuner, best $ for shortblock, intake, cams? Mustang46 99-04 3 July 16th, 2010 02:12 PM
head and intake opinions SickSnake95 5.0 Mustangs 5 July 30th, 2009 09:12 AM
NEED opinions on intake project PLEASE flamestang 5.0 Mustangs 15 January 11th, 2009 03:20 PM
