ARP head bolts? any suggestions?
Hey guys i have a built 306 with a v-1 supercharger...running gt40 heads and the head gaskets poped! i plan on throwing her back together this week but my question is i am using stock head bolts...anyone here of heads lifting due to re-using stock head bolts ? shout it be a must to replace the oem bolts with arp head bolts? thanks guys.
1992 Mustang GT
dont know yet
The stock head bolts are torque to yeild bolts meaning that they stretch when torqued. You should not reuse them as they are now weaker due to stretching.
There are 2 options go to the parts store and buy oem replacements (which can only be used once) Or go buy a set of arp bolts which can be reused should your heads have to come off soon for some reason. Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
yeah i was leaning more towards the arp bolts im not much of a stud man i feel safer using srp bolts rather than studs thanks for the info bud also is there any recomendation on which head gaskets i should use i want to buy the best possible no cut corners on this build. any suggestions?, thanks
1989 Black LX---Turbo
You might want to condiser some Cometic head gaskets while you doing it!
(I would go with studs!)
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
which cometic gaskets i here there nearly impossible to get..
89 GT
Studs have more clamping force than bolts do. Why would you feel safer with bolts as opposed to studs? Studs are stronger.
honestly just never used the studs does any one know the torque settings on gt40 heads using arp head bolts?
Threads Similar to: ARP head bolts? any suggestions?
| Best place and price for Head gaskets and head bolts?? | snake_bitten711 | 99-04 | 4 | May 24th, 2011 05:01 PM |
| arp head studs vs stock replacement head bolts. | DegralDan | 99-04 | 8 | December 25th, 2010 12:55 PM |
| head bolts? | Dolbs4082 | 99-04 | 4 | April 12th, 2009 08:43 PM |
| head bolts. | JBIGBOOTSY | 5.0 Mustangs | 5 | March 5th, 2008 05:08 PM |
| Head studs Vs Head bolts | turbong | 5.0 Mustangs | 2 | November 29th, 2006 04:28 PM |
