finally h/c/i done... buttttt not what i wanted
Old September 19th, 2011, 01:54 PM   #1
1989 Mustang LX 5.0
slow..help
rauscher89lx is on a distinguished road
so yeah. i finally saved up some extra cash, to have a buddy of mine swap out my original heads for gt40s, original intake for a cobra intake, as well as put a tfs1 cam in... i have a set of 30lbinjectors matched to a 75mm maf, but he said it wasnt necessary to put that in until i decide to blow it .... anyway, ive had the car back for about a week now, and am having some problems, hearing some noises... there is a consistent faint tapping going on around the driver side area, and when i decide to get on it, the tapping becomes louder, and almost hear like a slight grinding noise.... any suggestions? i was told that it could be the rockers, if not the lifters possibly? and could this be a reason why im not getting the correct performance out of the car?
also, sometimes she doesnt wanna start up right away after running for a bit. sometimes just give it a little gas and starts?
some of the other mods i have done just to get you an idea..
.70mm tb
.cai
.underdrive pulleys
.or xpipe & shorty headers
.subframe connectors
.lakewood dragshocks & struts
whatever it is that needs to be replaced, i should have the money to do... i am in the hunt of looking for a new radiator/electric fan setup, if anyone has any ideas.
thank you
Old September 19th, 2011, 02:52 PM   #2
VOGEL822 is on a distinguished road
id start with the rockers and lifters and go from there
Old September 19th, 2011, 05:36 PM   #3
1989 LX coupe 5.0L
header leak? happens all the time check for leaks and see what ya find
Old September 19th, 2011, 08:31 PM   #4
91cobra5.0's Avatar
98 Cobra
the gt40 set up is fun and all but you have to remember you are just now catching up to a stock cobra fox as far as engine power. unless you go with some aluminum or worked gt40 heads then you cant really expect a whole lot, your probly only seeing about 260rwhp. and +1 on the exuast leak
Old September 19th, 2011, 09:43 PM   #5
1989 Mustang LX 5.0
slow..help
Well, I plan on getting a blower asap now that I have t
he money
Old September 19th, 2011, 10:18 PM   #6
91cobra5.0's Avatar
98 Cobra
he money
with the right supercharger set up you can push the block to its limits but at the same time if you didnt have any porting work done to the heads and cam they will hold you back
Old September 19th, 2011, 11:00 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
dont use the 30ib. thats way to much injector for that set up unless you got the car tuned. 24lb is the biggest id go untill you have more done. i know that didnt answer your question but im not sure about your other issue
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old September 20th, 2011, 08:12 PM   #8
1989 Mustang LX 5.0
slow..help
I had it checked by another mechanic, he said its not a leak of any sort, def sounded like the rockers were rattling he said. Any specifics I should order?
Threads Similar to: finally h/c/i done... buttttt not what i wanted
So i finally bought my hood i wanted 93HatchsBFF 99-04 52 May 26th, 2010 03:22 AM
FNew guy finally got the Stang he wanted!!! cantbuytime 94-95 22 February 16th, 2010 07:21 AM
Finally Got The Exhaust Sound I Wanted! acehogg69 2005 - 2010 8 December 15th, 2007 04:34 PM
