2001 Mustang GT
13.8@101.58mph!
Ughhh another h-pipe question
Ok so i got every bolt except the header bolts out.Ive soaked these bitches for about 2 days,and they wont budge.I dont have a torch or anything like that.Do you guys have any tips that could help??It is the original h-pipe if that helps.And yes the bolts look rusty.
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
C Mor Semen
1995 Mustang GT
Not fast enough
Cheater bar! always worked for me?
![]() MAC CAI, SLP LM1's, Steeda short throw shifter, UPR O/R X Pipe, 3:73 gears, and more to come. |
2001 Mustang GT
13.8@101.58mph!
You mean a breaker bar right?? What if they snap?Can they be replaced? I have the stock headers
Extension(s), a good 6 point socket, and the largest bar you can fit under the car. If you apply good counter torque to the bar end and keep the socket straight and tight on the nut while you are turning it, it will either come loose or the stud will break.
If the stud breaks, you can try to pound it out or grind it down and drill it out or try to get a stud extractor up there. Then replace the broken ones with regular stainless nuts, bolts, and washers. It's tight in there but I had to do something similar.
1993 mustang gt
stock
Put a socket wrench to it hold it and start pounding on it wit sumthing with sum wieght while putting light pressure on it works every time and it is alot less straining on your body
1993 mustang gt
stock
I had a issue with my caliper bolts not wanting to break loose today i pulled and pried with all my might and nothing i picked up a c clamp put the socket wrench on and gave it a few taps while pulling slightly and they came right off
1995 Mustang GT
CRC Freeze Off is carried by Auto Zone. Around $6 a can. Has refrigerant in it to shrink the stud and spin nut off. Stuff works like a commercial!
2001 Mustang GT
13.8@101.58mph!
Well its raining here for the next couple days,nut ill pick up that crc stuff and give it a try.I also got an electric impact wrench off my buddy,do they really work???
1991 Ford Mustang GT
I use a 18" breaker bar with 3 feet of pipe on the end to break loose really tough bolts. The risk of snapping it is always there. I would try bubba95's idea of the freeze off then try to break it loose. Also you can get a propane torch at your local Walmart for probably $20 or less. Heat the area around the bolt and hit the head of the bolt with that freeze off and it should break loose.
1991 mustang 5.0
Impact gun. Harbor freight has a decent electric corded 1/2" one for $50. I had to get it when I did my control arms and u joints. It will come in handy and make life a lot easier.
2001 Mustang GT
13.8@101.58mph!
My friend just lent me his electric impact gun.Im gonna get some crc freezoff too.Gonna try first thing saturday morning.Wish me luck!!
Threads Similar to: Ughhh another h-pipe question
| Ughhh!!!! | brandon444 | The Clubhouse | 19 | May 19th, 2011 04:12 AM |
| Ughhh what should i do? | XxstarspyXX | The Clubhouse | 14 | April 14th, 2011 11:17 PM |
| Ughhh. | 02MustangV6e9 | The Clubhouse | 22 | September 3rd, 2010 12:07 PM |
| Ughhh! | 02MustangV6e9 | The Clubhouse | 40 | August 13th, 2010 07:43 PM |
| Ughhh | zinc02GT | The Clubhouse | 4 | September 15th, 2008 12:14 PM |
