idle problem
Old September 19th, 2011, 11:22 PM   #1
Dknits782 is on a distinguished road
idle problem
hey so i got a good deal on a bbk 70mm throttle body and installed it today but i have a problem with the idle. first i went to set a base idle at 800rpm but when i went to adjust the tps i could not get it below 1.4v i took both screws and i rotated it till it got down to .95 but the screw holes where way off. Also one of the screw holes is striped so it does not tighten down. I had to get home ( i was doing it at my parents more room to work) so i decided to drive it the idle was fine till it got warmed up then it would not idle below 2000rpm. when i got home i adjusted the idle screw and the idle dropped but the throttle is closed, only runs with the iac plugged in. Any ideas what could cause this does the tps influence the idle that much? Srry new to mustangs and this is my dd i cant take to many days off school.
Old September 19th, 2011, 11:26 PM   #2
jonrhy05 is on a distinguished road
yah, your TPS does influence it that much. you really dont need to take the screw all the way out. the holes should be oval to allow you to rotate the TPS once the screwms are barely loosened. for a quick fix...use a bigger screw(s) to hold the TPS
Old September 19th, 2011, 11:28 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
you need to E-long gate the holes with a drill bit in the TPS sensor. that should get you where you want to be
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old September 19th, 2011, 11:32 PM   #4
ok i will try that first. do u mean e long gate the depth of the holes or make the holes on the tps more oval? I really dont want to mess the hole up i have never done this before. thanks for the fast replies also
Old September 19th, 2011, 11:38 PM   #5
ryanw's Avatar
im not talking about the holes on the T-body. What im saying is to make the holes on the plastic TPS sensor slotted so that you can spin it more... In other words make the holes ovel
255 fuel pump,
3:27 gears
Old September 19th, 2011, 11:39 PM   #6
ok sweet thank u i will let u know how if it works
Old September 20th, 2011, 05:54 PM   #7
I made the holes longer and it worked idle back down ( just have to figure out my idle hang) thanks u guys for the fast accurate replies. Love this site defiantly the best.
Threads Similar to: idle problem
Idle problem? carney714 99-04 3 September 9th, 2011 03:22 AM
help with idle problem on a 95 gt mutlyi4 5.0 Mustangs 0 April 10th, 2010 12:25 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
Idle problem Pony_with_an_attitude 5.0 Mustangs 7 February 25th, 2008 11:37 PM
Idle problem Barrier Modular Mustangs 0 January 11th, 2007 12:38 AM
