1991 Ford Mustang GT
5.0 dart block vs. 351
For the longest time I've been considering the 347 stroker option with a trick flow setup, but my concern is whether the stock block will hold in the long run. My goal has always been 400-450hp since newer cars are making this but the possibility is there it may go higher assuming I get it all setup right. That HP goal is simply a minimum.
Would it be better to get a Dart block or would using a 351 4 bolt block handle this power well enough? At what HP would the 4 bolt 351 crack? I can still get the 351 cheaper and since I haven't bought the H/C/I set yet I may simply match these parts for the 351 option unless I'll run into a similar problem with it as the stock 302. |
1989 Black LX---Turbo
351w never came with factory 4 bolt mains. 351w block is stronger than a 302, especially if you get a 74-75 or older block. But any how, a 302 roller block will easily handle 400-450 na horsepower!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1995 Mustang GT
I have a 351w stroked to a 408 for sale. Lower Compression, AFR 205 Heads, Mild Cam, built internals etc...looking for like $3500 obo.
83mm Single Turbo 408. Built, Sumped, Boosted, Caged, Sprayed, Dropped. |
Threads Similar to: 5.0 dart block vs. 351
| Boss or Dart Block for build up. | Miami93LX | 5.0 Mustangs | 6 | November 14th, 2008 11:48 PM |
| DART vs. World Products block | ninetyonefivepointzero | 5.0 Mustangs | 8 | November 30th, 2007 06:42 PM |
| Boss block or Dart block??? | JONJON | 5.0 Mustangs | 48 | November 6th, 2007 09:37 AM |
| Dart block, sbf dart heads, 1 7/8 kooks SWAP tips. | purplepeopleeater | 5.0 Mustangs | 1 | July 30th, 2007 01:13 PM |
| 393 dart block 8:1 !!! | sn-95aac | 5.0 Mustangs | 7 | March 22nd, 2007 08:31 PM |
