Piston clearance for trick flow cam and windsor jr heads??
LinkBack (1) Thread Tools
Old September 20th, 2011, 09:43 AM   1 links from elsewhere to this Post. Click to view. #1
1989 Mustang GT
89fordified is on a distinguished road
I have some qndsor Jr heads but I am wondering if i will need to fly cut the pistons with a trick flow stage 1 cam. Any good real world advice????
GT40 Crate motor, BBK cold air intake, BBK headers, B&M shifter,BBK Springs, Off Road H-Pipe dumped off exhaust, Flowmaster
Old September 20th, 2011, 10:03 AM   #2
1989 Mustang GT
Windsor Jr*
Old September 20th, 2011, 02:32 PM   #3
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Probably not, but you should check PTV clearance anyway!
My son has a stock 93 short block with TF stage 1 cam, AFR 165's & 1.7
roller rockers with no PTV clearance issues at all!
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old September 26th, 2011, 08:50 AM   #4
Gregg@TrickFlow's Avatar
Gregg@TrickFlow is on a distinguished road
[QUOTE=horsepowerjunkie;3995108]Probably not, but you should check PTV clearance anyway!
This is a correct statement.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/233864-piston-clearance-trick-flow-cam-windsor-jr-heads.html
Thread Piston clearance for trick flow cam and windsor jr heads?? | Forums at Modded Mustangs | BoardReader This thread Refback May 14th, 2012 04:30 PM
Threads Similar to: Piston clearance for trick flow cam and windsor jr heads??
what trick flow heads 5.0 lover 5.0 Mustangs 9 November 16th, 2010 09:37 AM
Trick Flow Heads 2001MineralGreyGt 99-04 52 May 3rd, 2010 11:01 PM
Trick Flow Heads acmillr 99-04 116 February 24th, 2009 02:44 PM
4.6 trick flow heads? jrfan4life 99-04 16 November 12th, 2008 06:44 AM
trick flow heads fs again flattusmaximus78 5.0 Mustangs 6 March 28th, 2008 07:32 PM
