95ish5.0
Taking out the motor/trans.
So this Friday, my dad and I are taking the motor and transmission out of the car. its a 95 5.0 with a standard transmission. I was just wandering, any tips before we get this thing out? We were hoping to have it all done before the end of the weekend. We will be replacing the crank, gaskets, and a clutch. But yeah, any tips on getting the combo out would be appreciated.
1989 Black LX---Turbo
Make sure you go to your local parts store and pick up the fuel line quick release tool. Its a must! Other than that, just unbolt it and pull it out!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
95ish5.0
for the fuel lines up front correct? Dad said he had one for the ford lines, if it don't fit, ill pick one up. any other tips? guiding it out/back in? quick disassemble/quick unbolting?
Its a pretty simple deal really. Also don't forget to drain the trans fluid so it dosen't spill out the back as you are lifting everything out. Its also alot easier if you pull the shifter completly off of the trans. On the drivers side of the oil pan there is a single wire for the oil level sender, if you can't get it out, just cut the wire and use a butt connector to put it back togather.
Threads Similar to: Taking out the motor/trans.
| Got a new motor and trans in the stang | ma67cpe | Classic Mustangs | 7 | February 10th, 2011 09:30 PM |
| motor and trans mounts... | 99spaded | 99-04 | 3 | February 29th, 2008 04:23 PM |
| Installing the Motor and AOD Trans | OTreborO | 5.0 Mustangs | 2 | June 2nd, 2006 02:29 PM |
