#21 |
2006 GT
11.99@114
You need to find a tuner who is up to date with SCT. Try getting in touch with SCT they are in Lake Mary FL. They most likely will be able to direct you to a tuner in your area.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
#22 |
1989 Mustang GT 5.0
U will need atleast 42lb injectors
U should buy the aeromotive intank 340lph pump Quarter horse with binary editor for ur management and tuning Aeromotive adjustable fuel pressure regulator Leave the stock cam im making plenty of power and rediculous amounts of torque with the stock cam 1 or 2 stages colder spark plugs
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#23 |
1989 Mustang GT 5.0
O u will need an innovate motorsports wideband, a boost guage
Which ever maf u choose (hopefully a blow through) matched to the injectors A nice clutch with ample bite Wider,sticker tires
#24 |
1989 Mustang GT
~14@99 (b4 turbo)
my god this quarterhorse thing looks awesome. this may sound dumb, but can i use this in place of a dyno tune? like self tuning? whats involved?
306 w/ 8.9:1 ON3 70mm turbo kit - 9#'s boost arp chromoly studs 47# FRPP - 255 walbro 3.73 - tremec 3550 - zoom hp kevlar clutch msd 6a + blaster coil lowered. sfc. HID delete egr-smog-cats-a/c-foglights battery reloc QuarterHorse, BE, EA |
#25 |
89 GT
Yes you can, it's what I tune my car with. Just don't think it'll be cake to tune your car with and expect a lot of learning, and you'll love it. Check out EECTuning.org
#26 |
1989 Mustang GT
~14@99 (b4 turbo)
I had actually found that site last night it has ALOT of info on it. I'm just wondering how much its gonna be for these wide band sensors. Do they just replace my current o2 sensors?
306 w/ 8.9:1 ON3 70mm turbo kit - 9#'s boost arp chromoly studs 47# FRPP - 255 walbro 3.73 - tremec 3550 - zoom hp kevlar clutch msd 6a + blaster coil lowered. sfc. HID delete egr-smog-cats-a/c-foglights battery reloc QuarterHorse, BE, EA Last edited by VM0824; September 28th, 2011 at 03:34 PM. |
#27 |
1989 Mustang GT 5.0
I love qh! And be is 80 bucks to license. Its awesome
#28 |
89 FOX/01 WS6
0@0/13.1@106
May be worth it to change valve springs if you are running stock heads.
#29 |
1989 Mustang GT
~14@99 (b4 turbo)
what would be benefits of this? pros cons. what pressure springs? im totally ignorant on the subject other than you need stronger springs to stop valve float at crazy rpms
#30 |
1989 Mustang GT 5.0
The wideband does not replace ur current o2 sensors, im running the two that go into the ecu and then the wideband under neath the car
#31 |
89 GT
I paid 150 for my LC-1 wideband. Like ^ said, you add it to the system and do not touch your stock o2's. There's a few ways of doing it but if you don't have EGR hooked up anymore, you can actually turn that wire into an input on the QH and run your wideband to it. You just have to set up the wideband correctly enable the EGR as an AFR function in the QH and you will have wideband readings on your datalog screen.
#32 |
1989 Mustang GT
~14@99 (b4 turbo)
Ok so do I need to add a new o2 bung just for the sensor? I don't know where to put it? or which bank?
#33 |
89 GT
Doesn't matter the bank, and yes you need to weld in a new bung. The header collector is the ideal spot. Supposed to keep it parallel with the ground like your stock o2's are. So opposite a stock one in the same pipe is ideal. I have mine just past my collector in one of my mid-pipes and it works ok, but I'll be changing that to the collector in the near future to guarantee it's in the most accurate spot I can get it.
#34 |
1989 Mustang GT
~14@99 (b4 turbo)
ok 1 more question. when i put the turbo kit in, where do i put the 2 stock o2 sensors?, before the turbo where theres 2 different pipes? or after the turbo with only 1 pipe?
#35 |
1989 Mustang GT 5.0
2 factory o2 will be about a foot after the turbo, the wideband is gonna be under the car
#36 |
1989 Mustang GT
~14@99 (b4 turbo)
under the car?
#37 |
1989 Mustang GT 5.0
Omg ok ur turbo sits behind the passenger headlight, about one foot behind the turbo on ur down piPe, right before the firewall is going to be your two factory o2 sensors that talk to the ecu.
Then ur down pipe bends down towards the ground and to the back, this is where ur gonna put ur wideband under the car in the downpipe
Threads Similar to: getting her turbo ready
| My car is ready do you like it ??please look | ralphmustang | 2005 - 2010 | 23 | February 8th, 2011 05:51 PM |
| getting ready for a cam | mattf0509 | V6 Mustangs | 16 | December 2nd, 2010 02:54 AM |
| Almost Ready for the S/C!!! | Dawgfude03GT | 99-04 | 22 | November 1st, 2008 12:54 PM |
| All ready! | JASonic | The Clubhouse | 7 | March 23rd, 2008 01:20 AM |
| ready for some fun? | gooberhead320 | The Clubhouse | 20 | July 12th, 2007 10:24 PM |
