306,331,347 + Boost ?s
Old September 24th, 2011, 03:26 AM   #1
1993 Mustang GT
david1993gt is on a distinguished road
Send a message via Yahoo to david1993gt
what block for boost
I have been on the forums for hours and researching what people have done. I understand that the 302 is done right about 520hp at the crank... i want to know what block can i get 700hp at the crank and 600hp down to the ground... right now i got a 306 in there its safe and reliable to be driving around but not what i want in the end... I will have a turbo as my power adder so let me know your ideas thanks guys... sorry if my questions are a little behind the power curve second mustang first serious build..
Old September 24th, 2011, 08:35 AM   #2
1991 Ford Mustang GT
Stdyhand is on a distinguished road
Is this car for the street or strip? It's good to have a goal but I don't know of any regular street cars making 600 to the ground. However, I think you'd be better off going with a Dart block or swapping to 351 and maybe stroke it out to 408. It will give you the extra cubes plus the stronger block so it kind of helps you reach your mark easier.
I am considering the 351 idea myself and getting a stroker kit for it. I like the piece of mind that the block is going to hold together if I do end up making over what the block can handle.
Old September 24th, 2011, 11:41 AM   #3
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Dart, World Products, Ford Racing Boss, all make nice 4 bolt main blocks that will handle 1000+ HP!
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old September 24th, 2011, 08:57 PM   #4
saleen431 is on a distinguished road
I recently had a 331 stroker built with 10lbs of boost from a vortech v3 blower. I went with a stock block because i didnt want to go too crazy. I've got 482 rwhp. The guys that built the motor said 500hp would be close to my max. It runs like a champ and the blower is low maintenance. That's all I have to offer. Good luck. Just remember, the more hp, the more parts that need to be upgraded. It's ridiculous.
Old September 25th, 2011, 08:37 AM   #5
1993 Mustang GT
The motor i have is supposed to be a 306 with a bunch of bullshit done to it but as of right now i dont know because the guy said that its a gt40 lower with a typhoon upper and i was recently told that those two physically wont match up... So now im looking to build something on my own and do it all the right way the first time... now is 600 to the ground out of reach no but that is what i would like to be able to get out of my build if i turn up the boost and do the proper tuning. Would i be happy with a SAFE 500... yes i dont want to go the 302 stroker where 500 is borrowed time... so now i just have to find the best route for building and swaping these motors... What are your opinions on that
Old September 25th, 2011, 09:46 AM   #6
fogged306's Avatar
89 GT
These two responses are all the advice you need. Don't even think about using a production 302 block if those are your goals. A production 351 block and a good tune will live at those levels, especially if you're going turbo. Boost is easier on an engine than a N/A or nitrous set-up making the same power, and of the two FI set-ups, turbo is the easiest on the block because you don't have a blower belt tugging on the crank snout.
If you look around enough, you can find deals on aftermarket blocks. I picked up a dart shp with an internal balance 408 assembly for 3k shipped in the corral classifieds. All the machinework done and shortblock assembled. Deals are out there if you look and have some patience.
Old September 25th, 2011, 10:17 PM   #7
1993 Mustang GT
awsome thanks and i have all the patience in the world i dont want to rush and end up spending twice the money in the end... right now im just gathering a build plan and im going to start with supporting shit like suspension and trans
Old September 26th, 2011, 05:20 AM   #8
1995 Mustang GT
n/a
Silvernblue is on a distinguished road
going past 450 on a stock ford block is asking for trouble....do a 347 stroke FORGED SCAT 9000 series rotating assembly and the b303 cam, good solid dependable, STREETABLE power. Go with a low compression if you want to add a turbo.
Old September 26th, 2011, 10:22 AM   #9
1993 Mustang GT
I have been looking on Forged Piston | Stroker Kits | Crate Engines and they have alot of relatively cheap longblocks and they are all brand new... i think that ill pay the extra money to get a good combo... the 347 i was looking at with full rotating assembly, heads, and cams ran about 6000 and they are supposed to be able to handle up to 1000hp so that is well over my goal thanks again for all the help
Old September 26th, 2011, 11:35 AM   #10
fogged306's Avatar
89 GT
Don't bother with a dss engine. They use production blocks and claim stupid power handling numbers because if their "special" block prepping and main support system. It's all a gimmick. If you want something to last do what was mentioned before. Go aftermarket on the block or go to a 9.5 deck.
Old September 26th, 2011, 05:50 PM   #11
1995 Mustang GT
n/a
Dart block,fox lake block,chp block - all good blocks to start with.
1995 GTS - 302 bored to 306,holley 750 ultra double pumper blow thru,bbk headers,mallory distro,GT40p heads ported and polished,f-16 rollers,FRP slugs,granatelli underdrives,SLP loudmouth,t-5 world class,bbk short throw,TSW snettertons,nitto invos..
Old September 26th, 2011, 08:51 PM   #12
fogged306's Avatar
89 GT
Fox lake and chp don't make their own blocks.
Old September 26th, 2011, 08:58 PM   #13
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
OP, whatever you do, DON'T do this. A b303 is total shit in a 302. If you really want to spend a lot money, and have nothing but a slow ass, boat anchor TURD, then build a stroker and put a letter cam in it. While you're at it, just throw some GT40s on it, and crank that stroker up to about 300 hp. Never take advice from anyone who recommends a letter cam for anything. Especially something with more cubes.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old September 27th, 2011, 12:09 AM   #14
1995 GT
h949h is on a distinguished road
+1
Old September 27th, 2011, 02:26 PM   #15
1993 Mustang GT
thanks guys im going to keep my eyes open for some good deals around... i have nothing but time and i want to do this right the first time... Would you go automatic or what... i was thinking about swapping in a t56 v-spec but not sure what other things i have to change to make it compatable... has anyone dealt with a tranzilla befor?
Old September 27th, 2011, 08:10 PM   #16
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'm probably the only person on this site that will say this, but go auto if you're going to be racing it.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old September 27th, 2011, 09:01 PM   #17
uedlose's Avatar
89 Mustang
uedlose is on a distinguished road
what it comes down to is how much power do you really want to make? like said any of the REAL aftermarket blocks and Ford race blocks NOT Ford stock blocks that are so called modded to hold more power will hold 1000 HP and most even more.
the bigger the CID the bigger the turbo needs to be due to feeding the thing and getting rid of the spent exhaust gas. Turbos are far from one size fit all. How much are you willing to give up A/C, P/S. All of this can be a issue with turbos and large cid engines. is gone to be a T4 frame turbo or a T6? Really anything over 351 cid on a T4 frame turbo and you are starting to push Back pressure issues even some t4 frame turbos benefit from a 4in down pipe.
There are those that will tell you they have run a t4 frame turbo on a larger cid engine and yes they have BUT they will make no more HP then a smaller cid engine and some times less with the same size turbo due to there size. a turbo is only gone to flow so much air on the compressor side AND the exhaust side till it runs out of steam NO MATTER WHAT THE CID IS..
Now that being said you are in luck a 302 -351 will work nice on a GOOD t4 turbo and the nice thing is if you want more HP turn up the boost. I would not waste my time on a stock block other then a 351w block. they will take a good bit of power but they still can and will brake were as a aftermarket block will take a ton more and if the tune is off they tend to hold up better also. Nice thing about the 9.5 deck block you have lots more room for a ring package and nice long rods but rotating mass also goes up. and space goes down in the engine compartment. and the short 8.2 deck block offers less ring package room but at the same time people run them well into the 1500+ HP zone without issues at all. they are also lighter then the 9.5 block and they are smaller = more room.
If you want 500rwhp now, I can tell you now you will love it and want more. BOOST is a very addicting thing trust me and 500 rwhp will be just like driving your D/D in a year and you will want more at lease most people do I know I do, nice thing about a turbo you CAN have a 9sec street car and drive the thing like there is no tomorrow on nice days.
Like I said it all comes down to how much HP and $$$$ you have and want and what you want out of the car. dont forget the more HP you have the more $$$$ you will spend in a fuel system I can still remember writing a check for my system just the pump and reg. and 2 filters and a dailflow it cost me almost much as my R-block did. But it is the best of the best and prices on some of this stuff has come down. Think it out then think again then buy.
Just another turbo Mustang..No dyno numbers just good ets and MPH. And yes it is fast for a street car.
few parts for sale
https://docs.google.com/document/d/1...l=en_US&pli=1#
Old September 27th, 2011, 09:13 PM   #18
uedlose's Avatar
89 Mustang
Oh and as far as a auto or stick there is nothing better then a turbo car with a auto put it on the floor and never lift. never on and off the gas never falling out of boost or hardly dropping off any just point and aim. And never a missed gear
few parts for sale
Old September 27th, 2011, 09:39 PM   #19
Beerdog80's Avatar
1995 Cobra/1983 GT Vert
Beerdog80 is on a distinguished road
I'll join you. For consistency and elimination of human error...auto's are the way to go for drags
Sticks impress high school students. Auto's win races.
Old September 28th, 2011, 01:00 AM   #20
1993 Mustang GT
Now if im going to build some good power and smash it through an auto what do i have to do to make that auto compatable with my car and i plan to do this befor i do my motor so that i can just put it all right in the car and not have to worry about my trans.... and with the t56 i have 6th gear which still gives me some cruising what autos are good on the strip but still are street drivable
Threads Similar to: 306,331,347 + Boost ?s
Boost ? rider4life350 99-04 44 February 16th, 2010 11:27 AM
KB boost, need some help RyanGT 99-04 14 August 23rd, 2008 12:04 AM
How Much Boost? BLOWN89 General Tech 9 January 30th, 2008 08:59 PM
How Much Boost? BLOWN89 5.0 Mustangs 42 January 19th, 2008 05:12 PM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 09:56 AM
