1989 Mustang GT
will a lincoln mark 8 MAF work on a 89 Fox??
I'm trying to figure out if i can use a Lincoln Mark 8 MAF housing and use my stock sensor but for the calibration of 24lbs injectors...anybody know??
GT40 Crate motor, BBK cold air intake, BBK headers, B&M shifter,BBK Springs, Off Road H-Pipe dumped off exhaust, Flowmaster |
1991 gt vert
no def not for 24#'s the computer calibraits the injectors in stock aplications. aftermarket uses sample tubes or the electronics of the MAS, but this is really only fooling the eec. no stock ford MAS will properly run 24#'s without a tune
1989 Mustang GT
I understand that, I'm saying the maf Housing off of it...the houseing is suppose to be calibrated for 24lb injectors. And it would be the same in buying an aftermarket with the sample tube pike wat C&L performance does. I'm jus tryn to make sure.
1991 gt vert
no it woint be the same. no ford MAF stock sensor is calibraited for a certin injector size. as stated above. trust me it woint fly. in stock aplications injector size is tuned by the eec and NOT the MAF. it doesnt matter that the MAF came from a car with 24#'s. the best junkyard plug &play MAF mod is to use a 94-95 70mm MAF from a v-6 or v-8 mustang. this is with stock 19#'s
1989 Mustang GT
I'm only trying to fool the ecu. Lol I was just seeing if the housing off of a mark 8 would Wrk rather than going to C&L performance and gettng a mass air housing and a sample tube for my stock sensor.
Threads Similar to: will a lincoln mark 8 MAF work on a 89 Fox??
| lincoln mark vii | Pharoh | All Other Vehicles | 0 | July 5th, 2011 01:12 AM |
| Lincoln Mark 8 4.6 32v Engine ? | Bajis | 99-04 | 6 | July 25th, 2010 08:15 PM |
| Will Lincoln Mark VIII block work on 1998 Cobra? | cobra98sd | 96-98 | 14 | December 27th, 2009 03:18 PM |
| Lincoln Mark 7 | 93fourbangerstanger | 5.0 Mustangs | 4 | November 20th, 2007 05:59 PM |
| Lincoln Mark 7 8.8 Rear | 88LSC | 99-04 | 5 | October 30th, 2006 02:18 PM |
