serious problems
Old September 25th, 2011, 11:54 PM   #1
antl14 is on a distinguished road
serious problems
My mustang is a 1990 hatchback. it has a 8.8 with 3.73 gears,cobra posi diff., hardened 31 spline axles, and 5 lug conversion. the engine is new with a stock block, afr 165cc heads, trick flow track heat intake, anderson cam (not sure which one). it has been converted to MAF. I did not put the engine in and unfortunately the guy who helped me out has closed down. my problem is a rough start. i found a vacuum leak and put a cap on it and now my car take 3-5 times to start it up. on a cold start it will actually start right up but idle wildly until warm. without the cap i can hear the leak and my car definitely rides the same with and without the cap. Also, I always smell gas and the mechanic who fixed my car said its because my gas tank is broken. apparently the piece by where the fuel pump sits (walboro 190lph). another concern is the idle. it always seems to fall back at 1100 rpm and when i come to a stop it idles at 1500-1700 for at least 20-30 seconds before falling back to 1100. the computer was also tuned by the same mechanic with an sct chip. it is supposed to have 8 different tunes but he only gave me one for now. if someone could help me with advice i would greatly appreciate it
Old September 25th, 2011, 11:56 PM   #2
The car also has no airconditioning or egr. i just plugged up the holes coming from the throttle body.
Old September 26th, 2011, 02:15 AM   #3
powerstand89 is on a distinguished road
I am no mechanic, but I had similar problems and it was the throttle positioning sensor. Apparently, they are very fragile.
Old September 26th, 2011, 12:40 PM   #4
OK. i was going to switch the tps and iat sensor. when i do that ill hopefully see an improvement
Old September 26th, 2011, 02:37 PM   #5
88 347 stroker's Avatar
88 gt hatch
88 347 stroker is on a distinguished road
Pull the idle air controller off and cleaning it out as best as possible. They tend to get clogged up and can add to the problem or mask other problems. It's easy to do and won't cost you anything more than some brake clean.
Old September 26th, 2011, 09:15 PM   #6
Would a spacer between the iac work? Where could I get the right one?
Old September 26th, 2011, 10:47 PM   #7
1995 Mustang GT
Bubba95SN is on a distinguished road
Check fuel pressure do the EEC1V tests and cylinder balance. Post results.
Old September 27th, 2011, 01:31 PM   #8
Ok I'll give it a try
Old September 29th, 2011, 04:58 PM   #9
Sorry thought i was more competent. How are these tests performed. I have cleaned every sensor and still no better. after plugging the vacuum leak with a cap my cars cold start is 100% better. however, anytime i attempt to start it up after it wont start unless i hit the gas pedal. Do I need to get it re-tuned? the vacuum line i capped was the closest vacuum port to the drivers side under the intake manifold. if that helps
Old September 29th, 2011, 05:11 PM   #10
sspmustang's Avatar
1993 Mustang LX SSP
sspmustang is on a distinguished road
That sounds more like a Fuel issue rather then a IAC or TPS problem. This may sound stupid, but have you checked the fuel filter?
Old September 29th, 2011, 08:51 PM   #11
1995 Mustang GT
SBFTech has test proceedures.
Old October 4th, 2011, 08:23 PM   #12
I realize sbftech has the procedures but I can never seem to find them. Can someone post a direct link to this procedure? I also believe it needs to be retuned after plugging up the vacuum leak. I'm going to have to find a new shop
Threads Similar to: serious problems
98 gt problems 1989Gt. 96-98 23 November 23rd, 2010 05:56 PM
new with temp problems and trans problems 89Bullitt 2.3 Mustangs 4 September 18th, 2010 03:14 PM
2 Problems mcqueen V6 Mustangs 18 October 17th, 2009 01:45 AM
IAC problems?? NEED HELP!! 96trplblkgt 96-98 23 January 25th, 2009 02:36 PM
Fan Problems Jammess194 96-98 10 April 19th, 2007 11:06 PM
