5.0 question
I have a question in regards to one of my pulleys on my motor.
I have a 1988 5.0 Liter mustang. What is the name of the pulley next to the pulley that goes into the motor. If you are looking over the hood , it is on the bottom right side of the motor. All the other pullies are turning ,ie alternator, a/c , power steering . It it some type of smog pump ?
Have you driven a Ford lately ?
1992 Mustang GT
dont know yet
Bottom right under the ac pump is the power steering pump and right above the crank (which is the bottom most pulley) is the water pump pulley.
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
to make sure I understand you , it is the bottom most pulley.
What is happening is that pulley is not turning . The pulley next to it is going into the motor , [ center of the motor ] , isn't that the water pump area ? Sorry , I am a noob on this issue.
1992 Mustang GT
dont know yet
Ok looking at it from the front of the car. the really big pulley At the bottom is the crank shaft pulley the pulley directly above that is your water pump (your fan should be attached to that one) then moving to the right (drivers side) you have the AC pump and directly below that is the power steering pump. On the passenger side you have the alternator on top and the smog pump below that. Hope that helps
Sent from my Autoguide iPhone app Sent from my Autoguide iPhone app
yes, got it now , it is the smog pump pulley that is not turning.
I needed the definition so that I can order the part. I busted serp. belt & when i put the new one back on , we noticed all the pullies were turning except the smog pump pulley. I guess what I need to do is order the entire pump & pulley , right ? It makes a whinning noise when the car is cranked & motor running.
1992 Mustang GT
dont know yet
You may be able to delete it all together depending on your states emissions laws. Myself in California I cannot due to CARB laws here. But you on the other hand may not need one
1995 Mustang GT
Right side (passenger) left side (driver) Left and right is determined by sitting in drivers seat.
#8 | |
I am at work today & using my work computer.
One of you guys sent me a diagram of the belt setup. For some reason it is not showing up when I open my post . Could you resend the belt diagram please ?
Threads Similar to: 5.0 question
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| pro 5.0 shifter question + smog pump elimator bracket question | GMcanblowmyFORD | 5.0 Mustangs | 6 | June 28th, 2011 09:29 PM |
| cam with nitrous question, frpp manifold intake question | slater | 2005 - 2010 | 57 | November 14th, 2010 05:40 PM |
| Exhaust question and tuner question.....dont laugh lol | Drick | 99-04 | 19 | September 24th, 2009 03:42 PM |
| Muffler question (visual aspect) + Emblem question | warrior86 | Visual | 5 | November 20th, 2007 09:55 PM |
