1995 Mustang Gt
idle problem...or just normal??
to start it off..my top end is bran new..5k miles. This includes the trickflow upper and lower intake with space. 75 tb with a cai. Now when i shift my rpms STAY at the rpm i shift at. For example..if i shift at 3k between gears..it stays at 3k even with clutch in til i shift gears..normal?
also...when i come to a stop..my engine will idle at 2k for about 5-6secs b4 dropping to 1k...normal? thanks guys.
95' GT, Trickflow setup, Aluminum heads with 1:6 roller rockers, e303 cam, BBK shorties into Magnaflow exhaust, BBK cold air intake with 75maf, Highperformance waterpump w/ electric fans |
1993 mustang gt
stock
Def not normal it could be numerous things im no expert so idk wat it is i only know you have a issue somewhere try cleanin your salt n pepper shakers ive heard its fixed idle hang issues for some people
1995 Mustang Gt
call me old but what is the salt n pepper shakers????
1993 mustang gt
stock
1993 mustang gt
stock
The two black and white electrical connectors right above the 5.0 on the intake
1993 mustang gt
stock
If you search a couple pages back there was a recent thread that said somethink like "clean your salt and pepper shakers" with a useful link on how to clean them.
1993 mustang gt
stock
Page 3 at the bottom
1995 Mustang GT
Check for vacum leak.
mass air or speed density? clean MAF and IAC, if that doesnt, get a new IAC gasket and new IAC o-ring
1991 Ford Mustang GT
Check the throttle cable. Make sure it isn't binding. If it was sticking the RPM's would stay high until the clutch was engaged and the speed of the transmission would pull the rpms back down some.
1995 Mustang Gt
car drives excellant otherwise and the guy who i bought it from actually made a point to tell me it keeps the rpms when shiftin and he made it sound like an upgrade.
2001 Mustang GT
13.8@101.58mph!
My revs where hanging a bit too.I cleaned the IAC and after a day or so it started revving normal again.
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
I had this problem a few weeks ago and due to a dirty TB. Clean that and your IAC.
1988 Mustang: 5 speed, hurst shifter, plenty slow. |
2001 Mustang GT
13.8@101.58mph!
Maybe do all of the above
1995 Mustang Gt
tb is bran new..so?, i guess il clean it anyway
2001 Mustang GT
13.8@101.58mph!
Clean the idle air control!!
clean out the carbon build up inside the throttle body...a baby bottle brush does a good job with it
Threads Similar to: idle problem...or just normal??
| Tried searching... What's the normal idle, voltage for a 1996 Cobra? | 96SNAKE | 4V / SVT | 12 | January 28th, 2010 09:15 AM |
| procharger rattle noise at idle is it normal | footbrake | 5.0 Mustangs | 5 | September 20th, 2009 01:22 AM |
| whats the normal idle? | sickfox | 5.0 Mustangs | 34 | June 30th, 2009 10:28 PM |
| (04 Mach I) Normal Warm Idle oil pressure? | NewSchool | 4V / SVT | 1 | July 14th, 2008 07:34 PM |
| 1991 Mustang GT Normal Idle 1500rpm? | chozenfew805 | 5.0 Mustangs | 5 | November 23rd, 2007 08:39 PM |
