Break in
Well make a long story short. four cylinders two on each side only were firing but the car ran smooth as i broke the motor in. wouldn't hold an idle so i didn't try starting it again. Would teh ground coming out of teh wiring harness if not grounded well would it affect the injectors to spraying? and would one of teh alternator connections not hooked would that affect the firing of teh car?
Thanks Jon
1992 Mustang Notchback-306, road race project. |
is your car a 8, 6, or 4 cyl. first
[rides 1987 ford F-350 XLT Lariat 7.3L idi diesel projects 1979 ford F-350 custom (soon to get 7.3Lidi diesel) 1992 ford mustang notch (just shell soon to get engine and drive train hopefully) |
#3 | |
48.47@ 12.58
Its a 306. that would be an 8cyl. I'm not sure on how to answer your question man.. the notch guys will be on shortly though to help out
all motor
92 coupe
9.94@136.40
alternator doesnt affect the firing, the injectors do need a ground but i thought the computer grounds the injectors to control pulse width, but either wayyou need voltage to operate the injectors so connections are important. When u say firing you mean fuel?
1990 LX hatch
check for spark on all cyl.s, then take a screwdriver and press it against each injector, stick your ear on the screwdriver handle and listen for the tick.tick.tick. If you have to you can put two screwdrivers together, the injector noise is pretty strong, you may even be able to feel it with out listening to it. see if they're all ticking, car must be running.
well The car ran smooth and 4 cylinders were actually firing so fuel was getting to hte rail so either power is not getting to the injectors or they have failed. There the original injectors but they worked last year. Do all the grounds have to hooked to the back of the heads? I can only see 4 total ground for the entire car? I hope I am not missing any. Is the injectors on two circuit? thanks for your help
years ago i had injector problems , that i started getting after not hooking up all the grounds, after word i replaced the bad injectors and fixed ground al was good.
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion |
how do u no u were runnig on 4 cylinders? jus wanna no?
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
Threads Similar to: Break in
| trying to break 100 | HMUSN | The Clubhouse | 26 | April 2nd, 2008 09:08 PM |
| Will this break anything? | 06RedfireGT | The Clubhouse | 12 | November 9th, 2007 11:28 PM |
| Hey MSO, sorry to break the news | GTsetGO | The Clubhouse | 5 | November 1st, 2007 03:05 PM |
| t56 break in time | sonicblue | Modular Mustangs | 3 | June 28th, 2007 04:41 PM |
| Break-in period | burdman | 2005 - 2010 | 15 | May 14th, 2007 06:54 PM |
